Question about Xerox Phaser 8560MFP Laser Printer
Error 07.010.43:11249 on a Xerox Phaser 8560 MFP
    Genius:
  • 1,570 Answers
Hi
Error code 7,010.43 means that the Printhead is stuck in the tilted position, or is not able to tilt
forward to the print position, due to problems.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 Reboot the printer.
Did this correct the problem?
Complete. Go to Step 2.
2 Do the Printhead Restraints rotate
correctly?
Go to Step 3. Repair or
replace the
Printhead
Restraints.
3 1. Has ink spilled ink around the Printhead
that prevents the Printhead from moving
to its center position? You should be able
to push the Printhead right to left.
Clean the
Printhead
area.
Go to Step 5.
4 Is the Printhead stuck to the Wiper Blade? Start the
printer in
diagnostics
mode and run
idiags test
Exercise
Heater - toggle
Printhead
heaters to
soften the ink.
Manual
separate the
wiper and
Printhead. Set
them in their
home
positions.
Go to Step 4.
5 Does the X-Axis Motor drive the Printhead
to its center position (so it can tilt forward)?
Go to step 6. Troubleshoot
the X-Axis
drive.
6 1. Check the Process Drive for obstructions
or damaged.
2. Ensure the gears are correctly aligned and
homed.
3. Verify the process shaft and drive module
shaft are at their home positions.
Complete. Go to Step 7.
7 Has ink spilled on the Head Tilt Gear on its
drive train (near left side of the Printhead)?
Clean the
gears.
Go to Step 8.
8 Use Service Diagnostics to run the Head
Maintenance Wiper Clutch test.
Did the test fail?
Replace the
Head
Maintenance
Clutch.
Go to Step 9.
9 1. Align the Wiper Assembly (page 6-2).
2. Use Service Diagnostics to run the Wiper
Drive Test.
Did the test fail?
Replace the
Exit Module.
Go to Step 10.
10 1. Use Service Diagnostics to run the Load
Maintenance Clutch test.
Did the test fail?
Inspect the
maintenance
drive system,
replace any
defective
parts.
Go to step 11.
11 Verify the Head Tilt Gear engages. You can
manually set the Head Tilt Gear.
Is the gear engaged properly?
Go to Step 12. Set the Head
Tilt Gear.
12 Use Service Diagnostics to run the Tilt Axis
Drive test.
Did the test fail?
Replace the
Process Drive.
Go to Step 13.
13 Use Service Diagnostics to run the Process
Motor test.
Did the test fail?
Replace the
Process Drive.
Posted on May 21, 2011
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Feb 26, 2015 | Xerox Phaser 8560/YN Printer
07, 010.43:35874 Error on Xerox Phaser 8560 MFP
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward tothe print position, due to problems.
1.Reboot the printer.2.Clean the print-head area (You should be able to manually push the print-head right to left.)
May 22, 2011 | Xerox Phaser 8500/DN Printer
I have an 8560 MFP with a 04,024,45 error
Power OFF the Printer and Contact Support for Assistance. That's what the support website states. If you run out of warranty Xerox will charge you a call out fee before they even look at the printer.
Mar 15, 2011 | Xerox Phaser 8560MFP Laser Printer
We have a problem with a Xerox 8560 MFP with this error 37,008.44:34849. We don't known where is the problem. Can you help us ?
There is a problem with the power up of the printer. For 37,00x.xx error codes you can try power off the printer, wait 30 seconds and power it back on. According to the Xerox website for 37,008:44 error code you should Verify the Printer's Power Source and Isolate the Printer.
Nov 18, 2010 | Xerox Phaser™ 8560MFP Laser Printer
Xerox Phaser 8560 MPS System Error Press (?) 09,038.46:1252 Help Me Please... oolivas@gruposion.com.mx cvalabacillascity@hotmail.com
The ink-loader is defective and probably needs to be replaced.
The MFP ink-loader is unique, so you must buy PN 848K06380
Whit
Item, Inc.
Sep 13, 2010 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8560 mfp code error
Thanks for your assistance, but I found out the machine is still under warrenty and is scheduled to be fixed.
LeRoy
Jul 11, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
890 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
