Question about GE Dryers
How to get to heating elements on ge dryer model dde7200sblww
  • GE Master
  • 8,220 Answers
Most of the newer models you work from the front only. The heating coils are on the rear bulkhead of the dryer behind the drum. Unplug the dryer and take it outside. Set it on a truck tailgate or a table.
More Here
Posted on May 21, 2011
How to install a heating element in the GE wall mount dryer
GE Dryer design (Most or almost)....
Heating element access is from the front.
1. Remove the Front Door
2. Remove the belt.
3. Remove the Drum.
You see the heating element. Very simple design
Apr 06, 2015 | GE Dryers
GE profile dryer,Runs fine but no heat
need to have the heat element checked with a multimeter and visually if u can and look for burns and corrosion and breaking of the wire connections. Also have the thermostats checked, Im assuming its electric and not gas? the thermal cut off may be bad and the hi-lo thermostat, these can shut heat off from the dryer. Ive replaced the element on my G.E profile and it wasn't all that hard rather simple.
Sep 13, 2014 | GE Profile Gas Dryer Model Dpsb513gb0ww
Remove and replace heating element in GE Dryer
Not enough info! what is model number?
GE dryers has many models and each one has different procedure to remove heating element
Apr 20, 2014 | GE Washing Machines
GE Dryer DDE7200SBLWW -- dryer will dry on high heat for non permanent press clothes, but when you set timer and selector to Permanent Press it will not heat. Is this a thermostat issue or is the timer...
This dryer has 2 different cycle thermostats One is for 135f and the other is for 125 f. Maybe the 125f tstat is faulty? I would check that before ordering a timer. A good cleaning might do it also. Clogged dryer will overheat you know.
Sep 19, 2013 | GE Dryers
My GE dryer, Model no. DDE7200SBLWW, does not produce any heat. I cleaned all the lint, and have good airflow. All of the thermostats (4) tested good as well as the thermal fuse. With the dryer running on...
do you have 3 terminals to the heating element,if so check the neutral terminal,if this terminal breaks from heat stress the element can't function,not all have 3 terminals,if only 2 terminals then make absolutely sure theres 240 volts across these terminals,if not it will not heat,if you have some jumper leads of the correct size,bypass all thermostats,cycling switches and the thermal fuse just to make sure they metered out as good,also just to be sure check the terminal block where the power enters the unit for any high resistance or burned connections,if theres a hi resistance it will show 240 volts on a meter,but you won't get enough current thru the connection to properly heat the element,also flip the breaker on and off as these can be spookey at times too
Nov 21, 2010 | GE Dryers
DRYER WONT' HEAT #DDE7200SBLWW, VENT IS VACCUMMED OUT, STILL NO HEAT..CAN YOU HELP?
Unplug itb8186b9.jpgf75ef33.jpgbcd153e.jpg4f353dd.jpgCheck the heater element39cd6ae.jpg8f45608.jpg
Nice vid about homeowner repair of a plain Jane GE dryer:
More good stuff HERE
Aug 08, 2010 | GE Dryers
New Belt and pully-wont activate swith to start dryer
The main cause of this is improper bely routing. Click here and verify that it was routed properly.
SG
Apr 07, 2009 | GE Dryers
Need some assistance with a DDE7200SBLWW/model ge dryer
If the dryer is getting hot but not turning, you most likely need a new drum belt. If the belt is ok then you will need a new motor.
Dec 03, 2008 | GE DBL333EA Electric Dryer
Dryers Logo
179 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
