Question about Motorola Mobility RAZR V3
I have a Motorola Razor V3 cell hone iwth a cingular sim card in the phone. I am having trouble removing it. I have tried pushing down on it and it won't budge. HOw do I go about removing the sim card from this cell phone? Also after I finally get it o ut with your help can I place this sim card into my husbands RazorV3 cell phone so he can use it. I no longer use this phone and his Razor phone doesn't work very good and he would like to use mine. Any hle would be greatly appreciated. Thank-You , Judy Accurso
  • 2 more comments
  • Judy L Accurso May 21, 2011
    I amsorry, but you did not answer my question. I already know how to replace the battery and remover the cover. I need to know how to remove the sim card that is either stuck or it is very difficult to remove. I hae tried to ush down on the card and try to slide it out and it won't budge. What can I do to get this card out so I can let my husband put it in his smae type of phone.
    I am sorry, but I didn't get my problem solved from the other expert that answered my email. He told me how to take the back of the hone off and to remove the battery, but not how to remove the sim card from the Motorola RazarV3. I already know how to do all fo that, in fact the battery is out of the phone and the back is off and I just need for someone to tell me how to remove the sim card that won't budge no matter what I do to try and get it out. Is it possible to ge a pair of needle nose jewelers pliars to gras it when I push down on the sim card to see if I can get it out by doing that. Any help would be greatly apreciated.
    Judith Accurso
    Thanks so much for your help. You were very helpful. You were right; my husband has had his sim card in his phone for eons and eons, in fact he told me that he had never taken it out of his phone so knowing this you were absolutely 100 per cent correct in your summation about it being in the telephone for a long time and could be hard to remove which it was and it didn't come out.
    To be on the safe side I am going to take it to the AT&T Store and let them take it out and if there is a problem then it is AT&T's problem to make it good...and also by being their they can check to see how it is configured and make the changes.
    I plan on keeing this email with your instructions on how to remove the sim card in his phone, but removing my sim card if need be.
    You have been very helpful and I do appreciate it. Take Care and have a good weekend.
    Mrs. Judy Accurso
    Yes !!the second tech was very helpful and gave me the solution on solving the removal of the sim card from my husband's motorola Razor phone..
  • 4,737 Answers
I am sorry to hear that you didn't solve your problem with the help of the other expert. Well, it's not a difficult issue, but if you handle it without proper knowledge, you may damage it. If you've already removed the battery and the cover, you have only two steps to remove it.
Slide the sim card as shown below:
Press and slide it towards the right hand side (according to the picture shown above), it should slide out without any problem, but if it doesn't, I guess, it's never been removed for a long time or so. In that case, you can use a pair of tweezer, but don't ever use a pointed tweezer, that would damage your sim card. Use a flat head tweezer, a bigger tweezer will be better. Hold/Clip the two side eg. up and down faces, slide the sim card with your finger or you can use a smooth edge object to help push it while you pull it with the tweezer. Do this slowly, don't do it forcefully, make sure you pull it out to the right direction.
There is no lock or level to lock the sim card, it's just slided in to the slot.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Posted on May 21, 2011
  • Lebanon Raingam
    Lebanon Raingam May 21, 2011
    Thanks to you too and good luck. You too have a great weekend. If you can, I would appreciate rating my solution so that this thread will be closed and of course I will be credited. This isn't what I say ask you, but if in case (as many others do) you have problem rating my solution, I am only reminding you about the rating. When you click 4th thumb (from left), you rate it as solved and accepted, but if not, the your problem will be reposted automatically.
    Let me know if you have problem.
    Once again, thanks for using FixYa.
    Genius:
  • 1,196 Answers
1. Ensure that your phone is turned off.
2. Press in and hold the battery door latch
at the back an bottom of the phone. If it is not sliding out, exact little pressure to pull the cover off.
3. Carefully rotate the battery cover upwards and lift it completely off the phone and set it to the side.
4. Push in toward the bottom of the phone and lift the end of the battery first, it will free and you can remove the battery from the phone.
5.You can now have access to the sim, carefully remove the sim card.
Yes, he can use it, it will work fine as far as the phone is not configure with the phone from the manufacturer.
  • Ishola Olayemi May 21, 2011
    Slide the SIM card upward to remove it from the phone. With little pressure Slide the SIM card gently out of its holder with
    your fingers. You can pull it out of the holder from the top.
    You can also use an eraser
    from a pencil until its out enough to grab with your fingers
    comfortably. Try not to press down as much as push or pull it the
    direction its suppose to go out.
Subsidy password
Get the subsidy code for your Motorola model mobile from this site Theunlockspot.com , here it gives the code along with easy methods for your mobile .........
Jan 25, 2012 | Motorola Mobility RAZR V3
I put my sim card in phone from cingular end i have message :enter subsidy password . phone is motorola razor V3 ,and my IMEI is 356868008710493
I think you can try putting in like 1234 or the last 4 digits of your phone #. This happened to my dads razr. I think he ended up calling AT&T support line or something like that and he set up a number and anytime that message came up he entered it. Good luck
Jun 13, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
How to unlock a motorola v3 razor
take the phone to a mobile service center to have it unlock for a fee....or try online at unlockitnow.com or mobile2mobile.net
Dec 22, 2008 | Motorola Mobility RAZR V3
Unlocking Razr v3, Doesnt say enter subsidy password ???
you need to try online at unlockitnow.com or take it to a mobile service center to have it unlock
Oct 01, 2008 | Motorola Mobility RAZR V3
I want to unlock Motorola Razor v3 phone now with cingular.
Try unlockitnow or mobile2mobile and have them unlock it this may take a 12-24hrs process.
Or take the phone to a mobile service center to have it unlock
Aug 25, 2008 | Motorola Mobility RAZR V3
Unlock Subsidy code for Razor V3 Phone
Try mobile2mobile.net, unlockitnow.com or take it to a mobile service center to have it unlock there for a small fee.
May 24, 2008 | Motorola Mobility RAZR V3
Need a subsidy code
caspa3000 + yam9100 - take the phone and have them unlock the phone for you or you can do that online.
Mar 08, 2008 | Motorola Mobility RAZR V3
Sim unlock code
You should be able to get this from AT&T. If the first person won't help you, try again. They usually will.
Nov 29, 2007 | Motorola Mobility RAZR V3
Insert sim card
you need to have the phone firmware reflash...take the phones to a professional mobile repair store and have them fix
Nov 15, 2007 | Motorola Mobility RAZR V3
No reception? HELP??
It sounds like your phone is not unlocked. Did you get the phone through a different provider and your sim card through some one else? For ex, here in US, a cingular SIM will not work in a Sprint phone.
Jul 25, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
344 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
