Question about Simplicity Sewing Machines
I have a 2010 Simplicity Conquest with power steering. When the tractor drifts to one side, you can turn the steering several times before it changes direction. Unless you move the wheel sharply. Dealer says it's ok. Not for me . Help
  • 2 more comments
  • dfh298 May 23, 2011
    According to the dealer,this is normal with power steering.
  • dfh298 May 24, 2011
    There aren't any parts missing and everything seems to be tight.
  • dfh298 May 25, 2011
    It's not a sewing machine. It's a lawn tractor.
  • dfh298 May 27, 2011
    It's been doing this since new. June of last year. But it get worse the longer I mow. Could it be a check
    valve or something in the power steering?
    Genius:
  • 1,400 Answers
Hello
There are a few things that need to be looked at.The auto traction control.Tire pressure.And steering linkage.
I wouldnt say this problem is ok as did the dealer,its ok until you hit a tree or something else.
The tire pressure you can check.But the linkage and auto traction needs a mechanic to service it.
Here is a link to your mowers manual.
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=fmlvCHS.RFzXFix2
One more thing.Check for grease fittings around the front tires,linkage areas.If there are fittings then give them some grease.Somtimes dry bearings can cause this problem.
Posted on May 25, 2011
  • mpcheesman1
    mpcheesman1 May 27, 2011
    I could not find a detail drawing of the power steering.Possible low on fluid.Honestly this problem needs to be addressd by the dealer.
  • 1,238 Answers
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
  • 496 Answers
It dose not sound right to me ether. if i had to guess i would say you power streeing pump or some loss linkage. let me do a little looking. i just noted the time and need to run and get me little girl. i'll send you an email in a few.
M.Woodring
Posted on May 23, 2011
  • Simplicity Master
  • 1,133 Answers
This comment is from a Simplicity dealer I know "there is an upgrade to the steering on Conquest riders, that may overcome this problem, ask your local Simplicity dealer if he can provide this on yours".
Posted on May 22, 2011
Bobbin winder not winding cotton on spool a part has fallen in side machine how do l take casing off Janome 480 quilter thank you
Am unable to help with your machine but you can purchase a stand-alone bobbin winder called Sidewinder for about $30. Just be sure to verify that your machine bobbins will work on it. The one I have will use either a power cord or batteries. Great little machine because it saves wear-n-tear on the machine plus you can wind bobbins without unthreading the machine.
Customer Reviews Simplicity SideWinder Bobbin Winder Walmart com
Simplicity Sidewinder Portable Bobbin Winder
Amazon com Simplicity SideWinder Portable Bobbin Winder
Jun 05, 2017 | Janome Sewing Machines
Simplicity pattern 1291 view F. Instructions vague,ready to start sewing it together. Several pieces were cut on fold no indication if I keep them whole, my fleece does not march up with the size.
If the pattern instructs you to place the pattern on the fold, the folded fabric should be kept whole (do NOT cut the fold!).
You can probably contact Simplicity with your questions.
Oct 26, 2016 | Simplicity Sewing Machines
I have a Simplicity SE3 machine and I can not fine bobbins for this machine. Where can they be purchased?
The Simplicity SE3 bobbins are used for several other machines. The metal version of the bobbin is available here: http://www.mysewingmachineparts.com/top-quality-metal-sewing-machine-bobbins-125701-001-baby-lock-bernina-brother-riccar-simplicity-white/ . These are 10 for $6. There is a plastic version that's a bit cheaper: http://www.mysewingmachineparts.com/top-quality-plastic-sewing-machine-bobbins-136492-001-baby-lock-bernina-brother-riccar-simplicity-white/ . These two links include both other machines that use the bobbin and alternative part numbers to locate them from other vendors.
If you ask at a local sewing machine store for the Brother PE100 or BabyLock BL2100 bobbins, they should be able to help you find them.
I hope this helps.
Apr 17, 2013 | Simplicity SE3 Computerized Sewing Machine
What's wrong with the machine when the thread is skipping on top and bottom.
hi, it could be several things
damaged needle---try new needle
needle is not correctly inserted into machine----flat side of the needle goes to the back of the machine
wrong size needle for the fabric--choose a needle to suit thread & fabric
the wrong foot is attached--select correct foot
if you check all these things & they don't help then it's possible the machine is out of time
Sep 08, 2011 | Simplicity Creative Spirti PLus SA2200...
I need to change a needle in a Simplicity Serger SL370 but can't figure out how to do it....
for the two upper needles you use the "L" shaped tool that came with the serger. All you do is stick it in the hole for the needle you need to change. Upper leftish one is for the one on the left, lower rightish one is for the right side needle. That loosens the neelde and it slides down. Put new needle in, slide it up, put the L tool back in the hole and tighten.
Dec 04, 2010 | Simplicity SL370 Mechanical Sewing Machine
Simplicity snowblower stopped augerin. how do i change shear pin?
Make sure the motor is off and the key is out. Look on the center of each side of the axle that contains the blades. Rotate the blades slowly until you find the holes left by the missing bolts. stick a small screwdriverin the back of the hole to keep the keyway aligned. PLace the new bolt on the end of the screwdriver ( that should be facing you ). Slowly push the bolt through the keyway until the screwdriver pops out the other end. then attach the nut and tighten firly but do not overtighten.
Dec 10, 2009 | Simplicity American Quilter SA2400L...
Material pulling/shifting to one side
sounds like you're foot pressure is off, foot pressure and stitch length are the 2 main things that would cause "drifting" (they're also knobs that little hands could of moved) Also your little one quite possibly could of spun these knobs several times so keep that in mind while dialing your machine back to good health
Feb 13, 2009 | Sewing Machines
How to change a Needle
you need a set of allen wrenches... a very small one works
Sep 16, 2007 | Simplicity Serge Pro SW432 Mechanical...
Sewing Machines Logo
73 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
