Installion stops with this message "An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator." I am the only user of the computerand thus the administrator, so very annoying. Macafee security is running, but it asks if I want to allow AIR access and I've even tried switching off the firewall/spyware whilst trying to install AIR. I can't find the appdata folder that the install log is supposed to live in Any suggestions?
  • iw_anders253 May 21, 2011
    This problem is persistent! I've cleaned up my registry etc but I'm still getting the same error message when running as administrator and no firewall
  • 36 Answers
Switch off your firewall and right click on Adobe AIR setup and select Run as a administrator.
Hope it help.
Posted on May 21, 2011
    I tried this but got the same error message
  • horkyze May 21, 2011
    http://www.techburgh.com/2008/12/28/fix-...
    Try this if you updating from older version
    (Link to windows cleanup in post dont work so there it ishttp://download.cnet.com/Microsoft-Windo... )
    I'm sure it will fix your problem :)
Adobe air installer not working
Right click on the program select run as administrator.
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details Hope it helps.
Dec 28, 2012 | Adobe Systems Adobe AIR
In trying to install various versions of Adobe Reader on Windows XP SP3, I get the following error message: "Installation encountered errors; failed to initialize." I get this message on...
Yo! I will have to direct you to a website where you can download anything for your computer.i advice you download another one from here. please follow the link below..
www.download.com
Jul 27, 2011 | Computers & Internet
I keep getting this error: adobe flash player installer/ uninstaller 10.1 r10.2 has stopped working Its making everything run slow and the view of pages are very odd and plain.
Please try these steps:
1. Try to uninstall flash player by use Add/ Remove programs.(Start - Control Panel- Add/Remove Program)
2. Go to Adobe website download latest version of Flash Player and installer it. Adobe Website will verify the installation for you. Go here for the Flash Player
http://www.adobe.com/support/flashplayer/downloads.html
This can be done under administrator account only. If new message say you can't uninstall because program is in use, please open Task Manager and End Flash Player task then keep doing the uninstallation.
Hope this will help.
Thanks for reading.
Jul 20, 2011 | Computers & Internet
Photoshop 7.0 installation fails with the error message: "An error occurred during the move data process : -106" Upon install process it makes it to about 1% then gives the following error code....
one problem that could cause this error is lack of administrator rights,
right button click the setup.exe or whatever it called and select run as administrator,
Or if it's Vista try the compatiblity help , right button click the app, select properties and select run as XP service pack2 etc
Regards
gewiz.co.uk
Nov 30, 2009 | Computers & Internet
Adob Error 1625. This installation is forbidden by system policy.
start up and log in as the administrator then install cs4. You must have administration rights
Nov 13, 2009 | Adobe Flash Pro CS4 for PC
Share Printer (P2015) Installation error
You are probably log in as a Limited User using your Windows PC. You must log in as Administrator before it will allow the driver to install in the computer.
Jun 16, 2009 | HP LaserJet P2015dn Printer
I CANNOT INSTALL ADOBE READER 9.1 ERROR MESSAGE 1402 APPEARS
Do the following solutions first of all please remove all previous versions of Acrobat, and then reinstall.
1. Choose Start > Control Panel (Windows XP)
2. Double-click Add Or Remove Programs.
3. Select Adobe Acrobat [version] and click Remove.
4. When prompted, confirm that you want to remove Acrobat.
5. Repeat the above procedure for all installed versions of Acrobat.
6. Restart the computer, and then reinstall Acrobat.
Now, perform the steps below during Acrobat Reader installation. The Administrators group listed below is the default local administrative group for Windows XP.
  1. Write down the path to the key referred to in the error message and leave the installation running. For example: HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf\PersistentHandler.
  2. Choose Start > Run, type regedit in the Open text field of the Run dialog box, and then click OK.
  3. Navigate to the parent of the key referenced in the error message. For example, for the key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf\PersistentHandler, open (double-click) HKEY_LOCAL_MACHINE >SOFTWARE > Classes > .pdf.
    Note: These steps may vary slightly depending on the path in the error message
  4. Right-click on the parent key and select Permissions (HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf).
  5. Verify that the Administrators and SYSTEM is present and that Full Control is selected under the Allow column.
  6. In the Permissions dialog box, click Advanced.
    cid:1f55f5d78f3846839533f8a85e395973@joanne
  7. Select the Administrators group (1) and "Replace owner on subcontainers and objects" (2). Note: Select the current administrator account if the Administrators group is unavailable.
    cid:3ce74f38956e4dfcae487444ce8f86c9@joanne
  8. Select both "Allow inheritable permissions from parent to propagate to this object" and "Reset permissions on all child objects and enable propagation of inheritable permissions," (1) and then click the Owner tab (2).
    cid:be8ff9254ad94f29bec91706f67dc76b@joanne
  9. Click OK (3) in the "Advanced Security Settings" dialog box. Windows will now reset the permissions for each child object to correspond with its parent.
  10. Minimize the Registry Editor and click Retry.
    • If the error reoccurs with the same key proceed to Solution 4.
    • If the error occurs with another registry key repeat Steps 1-10 using the new registry key.
    • If the error does not occur finish the installation following the on screen instructions and exit the Registry Editor.
Please let us know how it goes.
May 06, 2009 | Computers & Internet
Error 1935 occured during installion of microsoft office
This issue may occur if a Microsoft .NET Framework file is being used when you try to install Office 2003. For example, this issue may occur if the Mscoree.dll is being used when you try to install Office 2003.
To work around this issue, restart the computer. Alternatively stop Windows Installer.
If these actions do not resolve the problem, repair the existing installation of the .NET Framework. Alternatively troubleshoot .NET Framework installation issues.
For more information about how to restart the computer and about how to stop Windows Installer, click the following article number to view the article in the Microsoft Knowledge Base:
308096 (http://support.microsoft.com/kb/308096/ ) BUG: Error 1935 during install of the .NET Framework For more information about how to repair an existing installation of the .NET Framework and about how to troubleshoot .NET Framework installation issues, click the following article numbers to view the articles in the Microsoft Knowledge Base:
306160 (http://support.microsoft.com/kb/306160/ ) How to repair an existing installation of the .NET Framework 824643 (http://support.microsoft.com/kb/824643/ ) How to troubleshoot Microsoft .NET Framework 1.1 installation issues in Windows XP or in Windows 2000 For more information, click the following article number to view the article in the Microsoft Knowledge Base:
926804 (http://support.microsoft.com/kb/926804/ ) Error message when you try to install a 2007 Office program: "Error 1935. An error occurred during the installation of assembly component" APPLIES TO
  • Microsoft Office Small Business Edition 2003
  • Microsoft Office Standard Edition 2003
  • Microsoft Office Student and Teacher Edition 2003
  • Microsoft Office Professional Edition 2003
  • Microsoft Office 2003 Personal Edition
  • Microsoft Office Basic Edition 2003
Please donot forget to rate these suggestions.
Mar 19, 2009 | HP Pavilion dv2000t Notebook
Acrobat 9.0 install problem
have you tried the Adobe Acrobat Support site?
Here's a link:
http://www.adobe.com/support/acrobat/
Oct 02, 2008 | Adobe Acrobat 6.0 Professional for PC
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
