Question about Fujitsu fi-5750C Flatbed Scanner
Scanner Display Shows False Jam
The scanner display on my Fujitsu fi-4340C falsely shows a paper jam.
  • 1 more comment
  • Anonymous Mar 17, 2014
    Where would one find a driver download for a fi-4340C needing to operate on WINDOWS 7?
    A fi-4340C flatbed scanner attached to a computer which was upgraded to WINDOWS 7...Do you know of a download online to help get us back up and running.
  • Anonymous Mar 24, 2014
    the entire page is black
  • 3 Answers
Check the sensors inside the ADF. They look like little fingers, one is probably broken off. That scanner only detects paper jams with mechanical sensors.
Posted on Jan 20, 2009
    Sergeant:
    Champion:
  • 271 Answers
You can try 1. reseting the scanner 2. uninstalling and reinstalling the software
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Posted on Aug 15, 2008
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
www.fujitsu.com/downloads/.../scanners/.../fi-5650c_ops-guide.pd...
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error Messagesmy.okidata.com/man-OF5650.../006B738F6240C3BF8525678500678C...Make sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Zealandwww.oki.co.nz/support/printer/.../index.aspxOki Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
Error Code : 0x5a
The detail code 5a in Fujitsu fi-5900 scanner is displayed due to frequent paper jam error. To resolve this issue, you need to clean the two lenses of JAM1 sensor and check it's performance.
Also, to resolve paper jam error, you need to check the condition of pick,separator,brake rollers, feed and pinch rollers. Replace the rollers if required.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Aug 01, 2014 | Fujitsu fi-5900C Pass-Through Scanner
Fujitsu fi 6130c sheetfed scanners make a clicking noise, then jam.
Hello Eddie,
The clicking noise could be due to abrasion of gears in the upper part of the scanner.Please check your scanner usage and a general service will resolve the issue with replacement of the gears, if required.You are recommended to contact your local Fujitsu authorised service station for repair. For more information, please visit www.fujitsu.com
Thanks,
ScanCare
Jun 15, 2012 | Fujitsu fi-6130 duplex scanner
Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
Jul 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
How do i reset the pick roller counter on my 4340c scanner?
First go to this site: http://www.fujitsu.com/downloads/COMP/fcpa/scanners/fi-4340c_maint-guide.pdf and download Fi4340c PDF, look over directions on cleaning Pickup Rollers be careful with handling delicate plastic moldings. After a good cleaning Test Unit. Now left ADF unit back as to service and power off a minute or 2. This should reset and bring back the normal "ready" display.
Jun 02, 2010 | Fujitsu fi-4340C Flatbed Scanner
False Jam at exit on a Toshiba DP3580 copier
make sure your drawer size shows 11x17 on display if not push user interface button then select the drawer and set it to 11x17
Jul 04, 2017 | Toshiba DP2570 Printer
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
Fujitsu fi 5120c e2 error
See page 25 of:
http://193.128.183.41/support/scanner/manuals/fi-5120c_gs_p3pc-1312-01en.pdf
"E2" is "Trouble with the optical system (front)."
That doesn't solve your problem, but at least it narrow downs the focus of your problem.
Dec 05, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fujitsu FI 5120C pop up error for paper jam
Please clean the separation pad and the pick roller.
If this don't help change them.
The Fujitsu sparepart numbers:
pad PA03289-0003
pick roller PA03289-0001
May 29, 2008 | Fujitsu fi-5120C
Fujitsu fi-5750C Flatbed Scanner Logo
725 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
