SOURCE: Hi, have lost the manual for my treadmill York
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
SOURCE: T3 Treadmill Stuck Key
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
SOLUTION
Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
SOURCE: asi image pro 2 treadmill error code 2
Loss signal or No Speed: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
