SOURCE: Hi can't seem to reload stapler
All you do is open the end peice and slide the staples in on the two rails, point down. You should be able to see in the end to make sure nothing is blocking the rail with a flashlight. You probably have the wrong size staples. You can only use # 214, 215, 276.
SOURCE: Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
SOURCE: how to remove jammed staples in staple gun?
Pinch the clip located on the end of the Magazine Unit Pull out the Magazine Unit Remove jammed staples from the channel. You may need to use long-nosed pliers . Make certain that you are using correct size staples. Close Magazine Unit.
SOURCE: I have a staple stuck in my Arrow model #ETN-50
Unplug it. If you can see the driver jammed against the staple, take a screwdriver end and try to push the driver back in and the staple should be released. If you can't get the driver to go in and release the staple, you'll have to disassemble it to clear the jam, If you need help with that, see the instructions for the current model here, page three, diagram 3, cleaning the magazine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Testimonial: "Thanks for your help! Much appreciated!"
SOURCE: reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
