Question about Dryers
My kithenaid dryer kes750j will not start. the timer and light still work but nothing happens when pushing the start button.
  • Dryers Master
  • 8,220 Answers
Well your model number ain't workin for me so I gotta shoot from the hip o this one. What I would first do is unplug the machine and take a look at the vent pipe for lint buildup. If you see anything that make cause dryer sensors to trip then clean that up before proceeding further. These kitchenaid dryers are top of the line Whirlpool type what I call 4 wheel drive models because they have 4 wheels instead of 2. When you get into the machine check the thermal limit beside the thermistor or control klixon whichever you have. That is if yall find lint build-up. If their is no sign of air restrictions then take a look at the door switch. It or the small lever attached to it might be broken. How to videos and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 21, 2011
    President:
  • 3,074 Answers
Make sure you have power to the outlet, make sure there is power to the back of the dryer, if you have all your power, open the dryers door and rotate the drum, if it spins freely the belt is off/broke. If all checks out then it is the door switch, well here is a website that will assist you, Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
My dryer does nothing when I turn it on...
Mar 10, 2010 | Dryers
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Doesn't start
Check the door switch. Also it could be bad contact in the timer.
Jul 21, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer won't start
Check your door switch and wires to see if they are damaged first.You may have a bad Start Switch.If it is a 2 wire switch you can tape them together and then plug in dryer ,if it starts,replace the Start switch. Please Rate this!
Jun 12, 2008 | Kenmore Dryers
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
