Unit overheats and shuts down automatically after a short period of time if it is placed in a poorly ventilated surface. however, with a laptop cooling fan pad, it works okay. the hot part is in the underside, left. whatever could be the problem? internal fan thing? thanks ^^
  • 3 Answers
Lab-tops are notorious for cooling issues. It's not necessarily a defect, but something that can't be fixed without a good ventilated area. the Lab-top has to get air from somewhere, and unless you don't mind not have a keyboard to use, the air intake HAS to be on the bottom. So the problem is a long known general issue with lab-tops. This of course would come from me assuming that the unit is a Lab-top. Hope the cooling fan pad is working nicely, and not too much of an issue.
Posted on May 21, 2011
My computer is automatic shutdown
Have you cleaned the fan, vents, heatsink? If a laptop overheats, due to dust, poor ventilation, blocked vents, it will shut down to prevent damage to vital components. Clean, improve air flow through the bottom and out the vents. Never use on soft surfaces that can block air flow. Contrary to the name, Laptop, it's not good to use on your lap. Go figure? If the Laptop is Clean and air flow isn't a problem, open Power Settings in Control Panel,and change Advanced Power settings to Sleep/Hibernate to Never, set to High Performance, unplug and remove battery when not in use. If you use mostly on AC remove battery.
Sep 24, 2013 | Computers & Internet
Gateway nv59c66u
If it didn't overheated in the past, then your laptop might overheat because the ventilation system doesn't work properly anymore.
Check if the ventilation is blocked in any way. Just to be sure, blow some air through the cooling fan vent (on the left side of your laptop). If dust comes out, then continue doing so until there is no dust. Also, if your laptop had this condition for a long time, then you should replace the thermal paste or thermal pad on your processor because it might have dried out and it isn't efficient anymore.
Another reason would be a faulty component. For example, if your laptop overheats near the battery and the battery itself overheats, then the battery is the culprit and should be replaced or removed until a replacement is avaible (for example, this issue was common in Dell laptops rendering the battery useless after a short period of time).
Also, high work loads make laptop computers overheat. If you play a resource demanding game for a long time your laptop will overheat for sure.
For better feedback, describe when does your laptop overheats and where (as a whole or a certain area).
Jun 13, 2013 | Computers & Internet
NP-RF710-S02US OVERHEATING WHILE GAMING
Try air in can or a vacuum cleaner to remove dust from the fans on the back and/or side of the laptop. If its overheating then removing this dust could provide better ventilation and cooler laptop. Also using laptop on soft surfaces, like bed, makes it overheat more.
Feb 07, 2013 | Samsung NP-RF710-S02US Notebook PC - Intel...
Laptop overheats
Use can air instead. Laptops are tough to open and even tougher to close correctly. Not to mention possibly damaging it.
Oct 08, 2012 | Computers & Internet
My TV keeps turning itself on/off at random times, sometimes it works, then turns itself off, and flashes on and off! Its becoming really frustrating as it seems to only work when it wants to for a short...
This could be caused by poor ventilation on the unit. The back of TV sets where the air vents are usually located are meant to be easily accessible to air. When they do not have enough air then the Tv tends to shut itself down due to overheating when it geths too hot.
Try relocating the TV position to an airy environment.
Hope this solution has been helpful?
Sep 26, 2010 | Televison & Video
I have a compaq presario x6000. every time i place the laptop on my bed and turn it on it cuts off within 5 minutes. but when I place it on a desk and turn it on it does not cut off. do not understand why...
The reason is because when the laptop is placed on the bed the cooling vents are blocked and the CPU overheats and shuts down. When the laptop os placed on a flat surface there is sufficient clearance between the bottom of the laptop and the flat surface of the desk to provide sufficient air circulation.
If you wish to use the laptop in bed then place the laptop on a flat surface and not let the bed clothes cover the laptop's cooling vents.
Aug 12, 2010 | Compaq Presario X6000 Notebook
If my laptop starts to smell like its burning and is really hot, should i turn it off? also, my windows automatic update won't work and i tried downloading additional windows software- is there any reason...
The burning smell you are experiencing could be hair, dust and debris that is stuck in the ventilation ducts and grills, power down the system, remove the battery. Get a few cans of compressed air from an office supply store. Now, take all the access doors off the base of the computer and using short bursts of air from the cans start blowing out the dirt and debris in the cavities and spaces on the computer. Make sure you pay very close attention to vents and fan grills, there could be a large amount of dust, hair etc. there stuck in the vents. If the smaell is more plastic in nature, shut the system and leave it down and seek professional tear down help.
Oct 03, 2009 | Computers & Internet
I bought today my acer and it shuts down after a while and restarts automatically right after
Laptops/notebooks are configured to go into sleep or hibernate modes after so many minutes of inactivity. The amount of time varies whether laptop is plugged in to AC power or running from battery. You can change the amount of time and how the power button behaves by changing your power managment settings in the control panel.
Oct 03, 2009 | Acer Aspire 7720 Notebook
I have a acer aspire 5735 and the bottem of the laptop is overheating and very hot and it shuts down the computer i have to wait till it cools down before it switches on again can anyone help thanks
Best Practices To Avoid Notebook Overheating
To avoid chances of laptop overheating, please follow these practices:
Clean the ventilation openings of your laptop at regular intervals with compressed air.
Always place your laptop on a flat, hard surface like a table etc. Don't place your laptop on blankets or other soft surfaces that can block the fans and air vents on the bottom of the laptop.
Never put the laptop in a restricted space where heat can build up and cause issues.
Install monitoring applications on the laptop that enables you to track the temperatures of processors, hard drives and other system components.
Regulate and optimize the power settings suitably so that the heat generating parts – such as the LCD and storage disc drives – power down if they are not used for a period of time.
If find necessary, you should use a laptop cooling device or a stand for raising your laptop to minimize the chances of heating.
If you are facing overheating issues and the laptop is currently covered under warranty from the manufacturer, report the problems so that the issue can be resolved.
Sep 26, 2009 | Acer Aspire 5735 Notebook
ACER Aspire 5720 overheat problem?
Try to keep as much ventilation under the laptop as possible.
You can pick up a can of power spray and blow out the unit yourself or have a pro. do it for you.
Dust and lint play a deadly part in overheating with laptops.
Walmart has Ventilation trays in which the laptop sits and is cooled by forced air from underneath.
Make sure the direction of air flow is the same as your laptop.
You dont want to push air into a output vent.
Aug 30, 2009 | Acer Aspire 5720 6497 Laptop
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
