Question about Refrigerators
Refrigerator getting too cold and feeeaing water despenser line and liquids in the unit
  • Refrigerators Master
  • 43,501 Answers
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on May 22, 2011
Water wil not despense
Could be a few things. Either the water filter is not in correctly. The water line could be frozen in the door or in the cold water reservoir that is in the refrigerator section behind the bottom drawers. You can tell if it is frozen in the door if it is a SxS by unhooking the water line before it goes into the bottom of the freezer door. Just unhook it at the pressure fitting and then try to get water. If it is frozen in the door then water will come out of the unhooked line when you try to get water. Also could be a bad water valve.
Oct 19, 2014 | Whirlpool Refrigerators
Why water is not coming out of the line to the freg
First check to make sure the water valve from th water supply is on (usually under your sink), Second, hold the water despenser switch ON. You should hear a "Hum" sound, that's the Electric water valve in the "open" position. The air will have to be purged through the water line, Filter, And the water collection tank inside the frig. The water tank keeps about agallon of water Cold for the water despenser, and will supply cold water to the ice maker, so the ice maker can freeze the cold water much faster for your ice. When holding the Water despenser, and you do NOT hear the hum sound, there is NOT power to the water selenoid. Check the connections to be ure they are tight and secure. A volt meter can also be used to check the voltage. WARNING the voltage is around 120 volts A.C., Do NOT TOUCH with bare hands!
Jun 20, 2014 | KitchenAid KSCS25FKSS Side by Side...
Leak when despensing the cold water
Check to see if there is a drain line in the water catcher if you have to open the door up you will find that the inner liner can be removed but may not have the drain line visible without breaking the internal insulation. In most cases the door is replaced , repair is the least of their thoughts when making fridges
Jan 04, 2014 | Refrigerators
Kenmore front load washer leaking by liquid despenser
What is the complete model number of your unit?
Dec 05, 2012 | Kenmore Washing Machines
Water will not despense through door?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. GE makes a heater that will prevent this from happing again. The part number for this heater is WR49X10173.
Feb 02, 2010 | GE Americana A4425GDTWW Side by Side...
Suction psi 30 liquid line 275 upon start up
seems a bit hi depoending on ambiant,
but you should be running like 160-10
Oct 04, 2009 | Delfield 406 / 406-CA Refrigerator
Bubbling water sound in AC. Water in the tray is cold. Unit continues to make a gurgling sound.
The gurgling sound is the liquid refrigerant going through the refrigeration copper lines , it's normal. And the water in the tray is condensation and is cold because is from the circulating air that gets cold going through the air handler(inside unit) You only has to keep the drain clean ,by pouring 1/2 cup of clorox every 3 or 4 months.
Sep 25, 2009 | Goodman Heating & Cooling
Why extra water line INSIDE my refrigerator
Hi, If you are talking about the tubing behind the crisper drawer, it is there to hold water for the dispenser in the door. The old design was a canister to hold water. Now it is tubing. I hope this helps you.
Vic
Jul 18, 2009 | Frigidaire FRS3R5EMB Side by Side...
My whirlpool side by side
If you can see the water running through the line when pressing the button in the door it must be going out somewhere inside or under the unit. If this is correct your plastic water line needs repaired.
let me know what you find.
Phil
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a lady Kenmore washing machine that when you put the temp on cold cold, it will first pour warm water through the front liquid despenser and then it will fill most of the way in cold from the back. ...
this is the way it was designed. cold water will not dissolve the detergent in the dispenser completely. if you want cold water only then connect cold water to both the hot and cold connections in the back of the machine.
Jul 16, 2008 | Washing Machines
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
