Question about Panasonic KX-TG5776S Cordless Phone
We hear nothing but heavy static on every phone connected with our base unit KX-TG5776S Panasonic phone, including the base unit. If we connect a differnt phone our home connection, there is no problem, so it is something with the phone itself.
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
  • 4 Answers
SOURCE: Panasonic KX-TG2367 says "No link to base".
This worked for my mother's KX-TG2357:
We tried doing what it said in the manual on page 54. That didn't work! She then decided to just unplug everything. About 3-5 minutes later, plugged everything back in, and lo and behold, everything was working fine!!
Posted on Feb 08, 2009
SOURCE: Static on Telephone Base Unit
Try powercycling the basephone and remove the battery from the cordless phone, wait for 10 sec and then reconnect the battery, after that connect the power to base phone,probably it will fix the issue.if your phone have the option to change the channel,try changing the channel to 11 or 6.try and get it fixed.
Posted on Apr 02, 2009
SOURCE: KX-TG2632 causing static to my baby monitor.
Baby monitors apparently are all on 2.4GHz frequency range. Phones have to be either beneath ie 1.8GHz or above eg 5.4GHz and no interference will occur. So simply had to change the phone because its frequency range was 2.4GHz.
Posted on May 28, 2009
SOURCE: Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Posted on Sep 10, 2009
Testimonial: "This responder did nothing but repeat my initial post and yet gets credit for a solution?"
RE : Panasonic KX-TG6461 I installed this phone
thats an hardware fail , you need a service shop to fix it
Sep 13, 2013 | Panasonic KX-TG6461ET DECT Corded and...
My panasonic KX-TG5000 phone headsets cannot make or recieve outgoing calls and the intercom function is gargly.
You need to reset the menu once again as it is possible that the phone had hung up as there was LINE PROBLEMS . Once this was reset the CLIP facility came back. So if you can once again remove power battery and keep aside to reset , then start all over to set up the base and slave units to MESH , the intercom and line facility must work.
You can remove the battery from the slave remote units to reset.
Oct 20, 2011 | Panasonic KX-TG4500 Phone
Panasonic KX-TG5652 How do I make it so I dont hear people leaving messages?
While the base unit is idle, press GREETING CHECK button then press VOL.(arrow down) button until "0" is displayed. I have included a link where you can download the manual if you need it.
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
Mar 30, 2011 | Panasonic KX-TG5652 Twin Cordless Phone
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
My phone is a panasonic kx-tga101s problems. Suddenly I can receive and hear calls, but my callers only hear static. Any suggestions? Thanks.
Try unplugging all units from the AC outlets as well as the phone connection. Leave disconnected for a few minutes. Re-connect all units and try calling out or have someone call in. this should correct the problem.
Aug 05, 2010 | Panasonic KX-TGA101S Cordless Handset
I am getting static on all handsets. What can I do to stop it?
sounds like it may be your phone lines or loose connection at the base station. buy a cheap hardwire phone to test this if the new phone has static it is your phone lines. if it doesn't have static check the connection to the base station.
Mar 12, 2010 | Panasonic KX-TG9341T Cordless Phone
My Panasonic KX-TG2352PW 2.4GHz cordless phone has loud static.
I don't yet have a solution, but I do not want to be obligated to pay for your advice...so I will find another way to solve the problem. Thank you.
Jan 01, 2010 | Panasonic Lands Phones
Mar 26, 2009 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TG5776S Cordless Phone Logo
22 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
