Question about Zephyr Typhoon AK2100 Kitchen Hood
My range hood starts and stops by itself all the time. If I need a replacement part, which one and where can I get it? Gracias
When open door trips breaker sometimes
has the cooking cycle stopped when you open the door
in these breaker trips
if no
stop the microwave before opening the door every time
if yes ..it has stopped
faulty microwave ...
you could try to replace door release catch
but think there is more to the breaker trip with the unit
time to toss it out and replace it
Jun 02, 2016 | Kenmore 1.7 Cu. Ft. Over The Range...
PK2229 blower stop working
Light and fan are two separate functions in your hood. The fan gets very greasy from the cooking. The grease doesn't act as a lubricant but as dirt. Remove the fan from the unit and check to see if the shaft is wiggling,or if it is seized. At this point you may need to replace motor. If it turns somewhat put a few drops of oil at the shaft, both ends if possible, and spin the fan by hand until it's loose. Replace back into hood and see what happens. Many times the bearings in these fans go dry and will not spin. GOOD LUCK FRIEND.
Jan 18, 2015 | Kitchen Ranges
We have sirius 900 built in. Lights (both) stopped working and apper fine upon inspetion. Fan works fine. I can also hear the light switch click every time switch is depressed. Help. Thanks.
You need to trace the path of the current (voltage) Start at the light and work backwards. Check for 110Vac at the socket. If its there you have a bad bulb, if not keep going backwards towards the switch until you find 110Vac. When you find it the problem will be in between the last 2 points you checked.
Aug 13, 2014 | Sirius Hoods SIU3 90 SS Island Range Hood
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Jul 29, 2013 | Kitchen Ranges
#23350303200 Kenmore Elite Range hood - Range hood exhaust motor slows down
You have 2 windings in the motor that create a magnetic field. A winding is simply a coil of wire an they do not touch. when applying the voltage (turning on the fan) the windings create the mag. field causing the rotor to turn, which then of course turns the fan blade. When these windings get weak it causes them to heat up due to the resistance in the circuit and you there for loose ur mag. field... Or if the rotor starts getting restricted it will also heat up the windings an cause the fan to stop.. Time for a new venta hood....
Dec 01, 2011 | Kitchen Ranges
Fan comes on by itself in a kenmore 55598 rangehood
I would suspect moisture has gotten into the switch. You may have to replace the switch if the innards have degraded.
Sep 15, 2009 | Kenmore Kitchen Ranges
Jenn-Air Hood - Turns on high by itself and will not turn off.
Does this oven work okay ,but the fan start when ever it wants?Can you tell me if it comes on when someone is walking around near it.No has to touch it.
Mar 15, 2009 | Frigidaire FMT144G1 Microwave Oven
OVEN BEEPS FLASHING -F7- IN CLOCK WINDOW
F7 indicate that the EOC (electronic oven controller) will need replacing. Parts are available at http://www.repairclinic.com/
Thank you for using Fix Ya
Please take the time to rate this solution.
Feb 03, 2009 | Maytag MER5755QAS CleanDesign Electric...
Random fan speeds and light levels???
I have the same issue. Have to reset the breaker to make it stop. Bet it is a bad controller (design fault).
Nov 13, 2007 | Broan-NuTone Allure III QS330SS Kitchen...
Zephyr Typhoon AK2100 Kitchen Hood Logo
95 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
The Vanguardian
The Vanguardian
Dale Copeland
Dale Copeland
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
