Question about Zhone 1518-A1-NA Wireless Broadband Router - 54 Mbps 1 x ADSL Network WAN, 4 x 10/100Base-TX Network...
I have a Zhone ADSL2+ CPE Router, Firmware version: 01.01.26. I did some test and I found the following problem. For this test, usually we did a ICMP test (ping test) to local , national and international common pages, like a google.com, yahoo.com, hotmail.com, Wikipedia.org and some others web pages. The ping passes the test from all that sites. When we try to load the pages from the above sites, the problem is that only the google.com web site is successfully loaded, and the others pages remain in loading state. This problem in BRIDGE mode/ with or without NAT,the firewall options was deactivated in the modem for the test . Can you help me please?
  • 106 Answers
Try tracert command to web site, that doesn't open. If trace is ok - than it can be yours web browser configuration, or pc firewall, or parental control. Try to open web sites with fresh install of another browser, disable windows firewall, any other firewalls/av and any parental control.
Posted on May 21, 2011
Usb driver for windows 7 64 bit
Looks like its only compatible with Windows 7 32bit
http://www.zhone.com/support/downloads/drivers/cpe/6211-Ix/Bcm63xx_ASUS_WHQL_usb_driver_5.2.3667.1.zip
Sep 11, 2013 | Zhone 6211-I3-200 Router
GLB-802C new firmware
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Feb 08, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
Ok, I have a Zhone 6211-I3-200 Bridge/Router or in other words a Paradyne ADSL CPE, and I cannot for the life of me get it to work with my Xbox 360. I used to have a different router and I would switch...
Zhone Modem Model #. 6211-13-200-0PA ADSL2 BRIDGE/ROUTER, AN.
I would like to upgrade current Firmware, but it is quite difficult and my ISP support even knows how to do this upgrade.
Nov 06, 2011 | Zhone 6211-I3-200 Router
Which is the latest firmware update for the 2540U Router? http://ftp.dlink.ru/pub/ADSL/DSL-2540U/Firmware/ is the only site I can find with updates on it but I'm not sure which to choose.
Make sure you download the correct firmware for you Hardware.
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem hardware (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Apr 28, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a zhone 6211-I3-200-ADSL2+CPE w/phone filter. I am trying to connect 2 computers (1 laptop, 1 desk top) to a linksys WRT 150n wireless router and cannot get the wireless connection to work. It shows...
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Aug 03, 2010 | Zhone 6211-I3-200 Router
Zhone 6218
To restore the router to factory default settings, select Management ->
Settings -> Restore Default.
I take it that is what you have tryed?
http://zhone.com/support/downloads/cpe/
try finding the correct firmware to install
Aug 12, 2008 | Zhone (6218-I2-200) Router
Ports wont open.
Hi, With a Xhone 6211-13 ADSL2 rOUTER, assuming that there is no firmware/hardware problem and that you have an active Internet account with your ISP, you have to connect the router directly to one of your PC (where you will do the configuration)(not through a switch or hub) and manually configure the PC's network interface: IP address - 192.168.1.2; Subnet Mask - 255.255.255.0; Default Gateway - 192.168.1.1 Check with your browser if you can already access the net, if yes then you have to probably set all your PCs to manual network config by just changing the last digit of their IP add. If still a no go, then.... log in to your router 192.168.1.1; username & password are both admin (default not unless it has been changed); at the Web Interface Home Page/Paradyne ADSL CPE Homepage check the general status & WAN settings. There would be indications that you are connected to the net. If you still cannot access the router (albeit being directly connected to it via a lancable, then check router's cable, if good but still no internet, then something is wrong with your router. Try hard reset (small button between LAN and Power at the back of the router, press for about 5 seconds or until it has re-initialize. Try again 192.168.1.1 in your PC's browser, if good, try internet browsing, if no go then something is wrong with your router. Hope this gives you some idea. Good luck and pls post again how things turn up. Kind regards.
Aug 09, 2007 | Zhone 6211-I3-200 Router
Zhone 1518-A1-NA Wireless Broadband Router - 54 Mbps 1 x ADSL Network WAN, 4 x 10/100Base-TX Network... Logo
428 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
