Hi.. I just got an Hitachi ED-X8250 3 LCD projector from a person. When I checked, the projector output is completely red but the picture and video still plays but with a red color sprayed fully. When a dark scene plays in a video, the darkest parts are red instead of black. Please help me with this issue. This happens even when viewing the default start up screen. Thanks and regards, Raj
SOURCE: hitachi pj-tx100 black and white picture when using s-video
s-video carries luminance and chromanance. In simple terms, luma provides a a black and white picture, chroma the color data. without chroma, you get no color. Either - the cable is bad (usually in the form of bent/broken pins in the connector ends - the source device is bad - the projector input is bad
Posted on Feb 13, 2007
MikeNJ1964
  • 398 Answers
SOURCE: brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Posted on Aug 21, 2007
  • 93 Answers
SOURCE: Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Posted on Oct 19, 2007
SOURCE: there is no picture
just a shot in the dark. this reminds me 'bout a problem with a Optoma (or maybe it was a Ask) i fixed. In that setup menu (on the proj), i was able to adjust the sync signal on the input. (I don't mean the the screen refresh rate..)  Just tried gradually step by step. Worked then!
Posted on Oct 27, 2007
dhiman
  • 115 Answers
SOURCE: Hitachi LCD Projector
Hello Dear,
This problem seems to be the main card problm which is connected with the RGB Panels of the Projector.
Viren
Posted on Nov 27, 2007
Projector lamp light red
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 12, 2014 | Hitachi Lamp for ED-X31 Projector
I am not getting any signal between my laptop and my projector. it is connected with a vga cable
You may need to turn on your laptops external VGA output. The easiest way is to reboot the laptop whilst connected to the projector whioch shoud be powered up.
If that doesn't work then look for the "Fn" key, usually blue or green on the botton left of the keyboard and hold it down whilst you press the "F" key (ie on the function row) which has a monitor icon in a matching colour. It may also say LCD, or CRT. This should cycle through available monitor output options, it will take a few seconds to complete the setup after each press.
Feb 16, 2011 | Hitachi CP-X260 LCD Projector
I have a Hitachi CP-L500 LCD projector. It is connected to my laptop from the svga projector port to the svga port on the the laptop. It is making no signal connection. I have made sure the input button...
I am not familiar with your Hitachi LCD projector . However , I do have a little knowledge regarding video signals and inputs / outputs as well as connections . If your connecting cable is one piece (has no adapters added to either end of it ) I would believe your problem is simply a settings misconfiguration in your projector / computer , or both . First , access your startup BIOS / CMOS settings during the initial booting sequence in your computer by pressing F1 or whichever keys you press when you turn the computer on to access it . Then , in the advanced list , check your primary video input selection to be sure it is default. Then, once the computer is completely booted and you can click on your start selection , go to your video settings and check how to switch between internal and external display options . I say this because it is important that you are able to reroute your video signal to your SVGA Out from the laptop (for sure) and it is in fact in that video output mode. Once you're sure you have a signal going out of laptop through that port , go to your projector video input selections menu and select each and every input option available until the signal comes through . This will only work if you're absolutely 100% sure that your video signal is in fact leaving the laptop via the SVGA port connection .
Sep 05, 2010 | Computers & Internet
Projector comes on, everything seems to work, wont recognize any inputs when they are plugged in, says that there is " no inputed detected"
There are several input that you will have to select. RGB for input from computers. There are also video imput selection if you plug it into a DVD player.
Aug 10, 2010 | Hitachi ED-S3170A LCD Projector 1700 ANSI...
Hitachi ED-X8250 - Turns off after 15 mins LAMP and POWER = RED
try looking for your thermistor usually located near the wind path its a small block the size of two match heads usually mounted off the main board with two wires this is your 'heat switch' so to say, also check your fans are clean and running there is normally more than one.
May 15, 2010 | Hitachi ED-X8250 Multimedia Projector
There is blue shadows in the picture, my hitachi cp-rs55 just got a new lamp, but the problem is still there???? How do i solve this problem??
Hi
The problem could be caused by the connection or configuration of your video equipment. Check the following:
  • Make sure your component-to-VGA video cable is properly connected.
  • Select Component Video as the Computer Input setting in the Signal menu.
  • Make sure the connected video equipment is set up to output video to component video.
Hope this helps
Apr 01, 2010 | Hitachi Performa CP-RS55 Multimedia...
Hitachi projector cp-s318 and the pictures give off a red tint.
Make sure the Computer Input is set to VGA, Computer, or RGB (depending on which projector model you have). Go through the menu settings of your projector.
Hope this helps
Apr 01, 2010 | Hitachi CP-S318 Multimedia Projector
reset the lamp and filter timers. turn the projector off then back on.
Mar 29, 2010 | Hitachi ED-X8250 Multimedia Projector
Hitachi ED-S3170 Projector problem
If the bulb is under warranty then take it back.
Jan 26, 2010 | Hitachi ED-S3170 Multimedia Projector
There is no picture
Sep 21, 2006 | Hitachi PJTX100 Multimedia Projector
jasbo
jasbo
