Question about Yard Machines Garden
MTD Yard Machine edger recoil rope won't pull.
SOURCE: I hit a rock and bent the blade on a yard machine.
I did the same exact thing over the weekend, try adjusting your new blade unscrew the main bolt to the blade about 1/2 turn that should get it spinning again, same exact thing happened to me. Good Luck
Posted on May 18, 2009
scott586
  • 41 Answers
SOURCE: Starter rope too hard to pull on Yard Machine By MTD
Not sure if this will help. Don't want to sound like a **** but....Have you made sure nothing is caught or jammed inside it. This could make it hard to start with the cord..
Posted on May 19, 2009
  • 4088 Answers
SOURCE: PULL ROPE WON'T RECOIL AND IS FULLY OUT
Possible broken return spring or excess junk in starter mechanism. Remove starter assembly to check out.
Posted on Jul 04, 2009
SOURCE: I have a Yard machine by MTD, Model # zr700r.
You nnnd to un-screw the srews that attach the housing to the engine. There will be 4 more srews to un-screw to get to the cord
Posted on Aug 04, 2009
  • 68 Answers
SOURCE: WeedEater Edger PE550 Starter Rope will not recoil
Order a new recoil spring from your suppier. It comes wound up. Remove the old part first usually four screws on the outside. Make sure the rope is fully wound then insert the new spring and reassamble. If it becomes unwound by mistake its a labourious job to rewind but can be done.
Posted on Aug 30, 2009
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
How do u remove recoil spring assembly that is held in place by a roll pin on a 4hp Briggs and stratten
I suspect you asked this question because your recoil starter rope has broken , so first let me say be extreemly carefull the coiled spring on top of rope pully has a lot of tension to it , it can and will hurt you if it gets out of the pocket it sets in, what ive allways done is to NOT remove the pully at all but hold it with a large C clamp i put this on right after i get about 6 good turns to tighen the spring then i apply clamp , use a razor knife to cut ball off end of old rope and pull out using pliers thread new rope from outside rope guide to into the rope pully and knot if off in original hole (use a lighter to part melt rope end) measure off about 5 feet of rope and tie starter handle on there then its simple just slowly let clamp pressure off the pulley will pull rope in to cover automaticly done !!!
Aug 24, 2014 | Mtd 22" Yard Machine Push Mower
How do i replace pull cord on mtd 31cc tiller
Remove your recoil housing. Turn the inside to see if spring is broken. If spring is good wind it up as tight as it will go without forcing it. Once you have it wound all the way then back it off one turn or until the eyelet meets where the rope comes out. tie a knot in one end and feed through both holes. Pull the rope through till the knot is tight then attatch your handle. Once the handle is in place slowly let the rope wind itself in. pull a few times to make sure your knot is holding and reinstall on engine
Jul 16, 2014 | Yard Machines Mtd Yard & Garden Cultivator...
Yard Machine Model 21a-121r900 tiller's pull starter recoil pully slipping
Bend the ears on the flywheel so that they are 90degrees. They are not lining up right.
Feb 16, 2013 | Mtd Garden
How do I reset the starter cord to rewind. It does not recoil when I pull it to start. I have to take the cover off and do it manually.
Hopefully you don't have a broken recoil spring. If the spring is not broken, then it's just a matter of rewinding the starter rope with the spring tension wound. I'll give you links to my two favorite videos on how to do this, as each machine is similar, yet slightly different. After viewing both videos, you should be able to do this on your machine:
Video1: http://www.youtube.com/watch?v=GyjQir3b3xI
Video2: http://www.youtube.com/watch?v=i3ZMVFi0yqY
I hope this helps. Best of luck to you.
James
Sep 06, 2011 | Mtd 22" Yard Machine Push Mower
I replaced the pull cord on an mtd mower. and now it won't rewind the cord?
You have to tension the spring before installing the cord. Remove the cord. Put the recoil assembly in a vise. Prepare the ends of the cord so they can be threaded into place. Spin the pulley in the proper direction until it is tight. Align the hole in the housing with the hole in the pulley. Thread the rope in and knot it and pull tight. Slowly let the spring tension retract the rope. Cut the rope to length, install handle, knot and test.
Gary
Aug 27, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
Pull string won;t recoil
The recoil spring has broken. These are available at any lawn mower parts supply store. The process of changing the spring is tedious but can be done by anyone with average mechanical ability. If you removed the recoil assy (and air shroud if it is riveted on) and took the assembly to a Lawn Mower Repair shop usually they will change out the spring while you wait. If you can't get the recoil assy off take the mower with you to the repair shop. Again most shops will fix it while you if wait but if they are very busy usually they are serviced within 24 hours.
If you do attempt this yourself check in the tips section of FixYa on how to change the recoil stater rope after replacement of the spring.
I highly recommend you replace the pull rope at the time of the recoil spring replacement.
One final note... there is a possibility that the pull rope spool has been damaged where the spring attaches.
Thanks for using FixYa,
Kelly
Apr 28, 2010 | Mtd 22" Yard Machine Push Mower
Replace pull rope
Yes, take the shroud off that the recoil is riveted to
Apr 15, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
47 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
