Question about ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET 1155 - DDR3 SDRAM Motherboard
Cannot enter BIOS - new system load. DEL key works but does not get me into BIOS. System moves into Marvell SATA load but then hangs with pixelatd screen. Can restart process with any key. POST goes through CPU, VGA OK but BOOT_DEVICE_LED stays red. Processor: 2500K, memory 2 x 4gb Corsair Vengeance CMZ8GX3M2A1600C9, video: Radeon HD 6870
  • 1 more comment
  • stephen_box May 21, 2011
    I have tried all of the usual keys to enter BIOS such as F2, F10, etc. The screen indicates the DEL key. Keyboard is MS Wireless Desktop 800
    I have tried everything learnt over some 30 years with computers, including clearing CMOS. The ASUS forums indicate similar problems.
  • stephen_box May 22, 2011
    Thanks guys but FixYa suggested specific skills relating to my motherboard which is already at revision 3.1. I have had problems with the initial startup of 3 generations of Asus 'Pro' motherboards. Asus technical support responded today to tell me that there is an omission in the manual. So the solution is that, to clear CMOS you not only have to remove the power cable and wait for the motherboard LED to die, you must also remove the motherboard battery before moving the jumper. After this all was good. We now have the next problem of an unwanted reboot after about 30 mins, but this is a known problem with a known solution.So thanks, but I have resolved this problem myself.
  • 4,737 Answers
It's good to hear that your problem is resolved. I was also going to tell you the same thing, to clear the Bios Settings and restore it to it's default value by removing the battery or by swapping the Bios jumpers. Well, I just wanted to add few words. This is a rare issue, and in most cases this happens when the BIOS chip itself is bad or there's electronic issue (faulty with circuit or other similar components) on the motherboard. Yes, it's been fixed for the time but, but this may also repeat in the future, and I would also say that if this happens for the second time, you may not be able to repair or reset it. I've had the similar issue with one of my older motherboard, and I wasn't aware after it was simply fixed by resetting the Bios. One month later, without any alert or error, the system just completely stopped working, I tried my best but to no avail. The unfortunately thing was that I was only starting my backup while this happened and so most of the files or projects were saved on the C drive where windows is installed. I was trying to boot up with another motherboard using the hdd but in the normal mode, it didn't because there was driver conflicts (and I was unable to find the same motherboard model). Installing the Hdd on another system, I tried to access the C drive's My Desktop and My Documents, but I couldn't for I'd set the my account's permission to "Private". Very disappointed, I installed it on another system (only that hard disk), boot into Safe Mode and there came up another much more disappointing issue, the User account I had been working was "locked out" and I couldn't log into my account even in the Safe Mode, luckily the installed o.s. was Windows XP and I remembered the admin password, so finally, I got accessed into my system with the Admin account and got everything moved and backed up.
In the same way, this could happen to you as well, so I would like to suggest you beware before it stops working completely. Yes your problem and my problem might be different, but if in case, they are similar, I wouldn't like others facing further similar problem or loss.
When reading your comment, it looks like someone told you to unplug the power cable, wait for the motherboard led to die to reset the Bios settings. If I am not wrong, I haven't heard about anything like that to reset any motherboard bios settings. Forgive me if I am wrong.
I am only sharing what I know of, so my knowledge may not be applicable with your problem. If you need further help, let me know. I am ready to assist you further.
Good Luck.
Thanks for using FixYa.
Posted on May 22, 2011
  • 4,281 Answers
Open the cpu cabinet cover.Reconnect RAM memory and processor make sure motherboard is not ground with cabinet cover.Pull cmos cell from motherboard for 10 minutes then check. Reconnect all connection to motherboard. When you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios. Let me know if you need further assistance. Thanks for using Fixya.
Posted on May 21, 2011
  • 3,530 Answers
Welcome to Fixya
You will actually see the key to press to go to Bios when you turn on the computer. Some computer will say press F2 or F10 to go to setup. check your screen while it is booting you will see what key you should press to go to setup/Bios. But normally tapping on F2 or F10 while system is booting will take you to BIOS setup screen.
Thank you for using Fixya!
  • Jose Cada
    Jose Cada May 21, 2011
    have you tried using a wired keyboard first? this is a common problem if wireless keyboard is not paired to computer that is why it is not responding.
Attempting to install OSX on WD7500BPVT Hardrive. OSX says HDD is locked.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
if its password protected (locked)
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps.
Jan 14, 2013 | Western Digital 750 GB Scorpio Blue SATA...
Can I boot to BIOS without an operating system
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
this will set the boot order
hope this helps
if this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Oct 28, 2012 | Lenovo ThinkPad R51
Booting problem
have a close look at the screen it will be quick you will see which key to press to enter bios
hope this helps
others you might try
Sep 27, 2012 | Sun Blade 2500 PC Desktop
I have tried to add a second SATA drive but it causes my system to hang. I have tried the various system settings in the Southbridge area of bios set up but all fail. I tried connecting to the other...
Ok when your adding more the one drive you are creating a SATA raid, There are drivers that do need to be installed within the windows env. So this will not hang on you.
You need to visit Asus website and download the SATA drivers if your putting more then one drive in this mothership. This will use the secound drive as a hot swap, Remeber SATA is not IDE and vice versa whenever your putting a secound sata in the system will thing your trying to raid the secound drive.
1. check the drivers
If you have any questions please feel free to ask, otherwise please do rate your answer I gave before you leave, Thanks
Aug 17, 2010 | ASUS P5VDC-MX Motherboard
I would like reset the password of my d33005 motherboard
Go into the BIOS setup to reset the password. Start by rebooting the system. Before the system starts loading the operating system, the computer will give an opportunity to enter the BIOS setup utility. Usually a screen appears saying to press a key to enter the setup utility; i.e. "Hit DEL to enter Setup". You have to know what key the computer is looking for to get to Setup. DEL in used on the a lot of ASUS machines but you may that to refer to a manual or read the screen just before the operating systems to load. Once you get in, look for something related to security settings. Once it is found under the boot tab. Here is where you can reset the motherboard password. Hope this helps.
Dec 15, 2009 | ASUS Computers & Internet
Main Hard drive crashed- Cannot enter bios to add new main drive
OK, first, why no keyboards working..? USB keyboards maybe..? Next, is the system booting..? If yes then maybe you have lost the keyboard controller chip, if no, then you have a usb legacy support issue. Next, why do you say your hard drive has gone down..? Drives and bios are not connected, if the drive has gone down, why do you want to access the bios..? the bios runs the system until all the legacy drivers are loaded, then it passes control over to your operating system which loads from the drive, but the bios doesn't really do anything to the drive, most mainboards automatically sense the drive is there and how big it is but thats about all.. Next, if it is a drive, try using a usb to sata drive converter and plug the drive into another system, then you can examine the drive and maybe fix the issue if it's a boot or software issue. Some sata drives can ( and do) have an issue with their firmware ( the circuit on the drive) and I have found that if you remove the circuit board (carefully), clean the contact points and refit the board ( carefully) you can resurrect the drive.. so maybe give that a try.. If all else fails, try fitting the board to another system or try another bootable drive on the board..
Nov 21, 2009 | Computers & Internet
Biostar gf7100p-m7s hard drive not working
I would flash the BIOS, sounds like something is corrupted, if that doesn't work then the blame has to be the HDD, you need to try booting with a different one, maybe a PATA too see if your problem goes away or changes. Any PATA will do, this is only a test.
http://www.biostar.com.tw/app/en-us/mb/bios.php?S_ID=348
Another SATA would even be better. Good luck.
Jul 15, 2009 | Computers & Internet
MSI board-no video or booting.
  1. Clear the CMOS by moving the jumper one step aside which located near the CMOS battery for at least 30 seconds with power cord unplugged, then put it back again to its normal position.
  2. Enter BIOS by tapping Del then load the Optimized Default, then Save by pressing F10 key.
  3. You can customize the BIOS after computer has been starting & running properly.
  4. Please check RAM and VGA card whether they have properly attached in their slots before you do the 1st step.
  5. If all above don't work, please replace your VGA card with other PCI-E VGA card that is still working fine.
  6. If all above don't work either, please replace the PSU with greater output from better brand. You can visit www.corsair.com to calculate how many Watts your system is needed for free.
  7. If hell still can not boot or no display, replace the motherboard
Apr 09, 2009 | Computers & Internet
ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET 1155 - DDR3 SDRAM Motherboard Logo
191 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
