Question about Homelite Gas Fuel Cap Blower Bp250 Bp250i Bp30185 Bx90
Homelite bp250 blower will only run full speed at half choke. will not idle. I have tried to adjust carburetor with no change in results. I keep air filter clean and have installed new spark plug and cleaned the spark arrestor.
mindreader
  • 578 Answers
SOURCE: I have a homelite model uto8550 26cc mighty
1. check fuel filter in gas tank (for clogged condition).
2. Check carb jet for dirt (squirt carb cleaner in jet and fuel inlet
Summary: your carb is not getting enough fuel to mix properly with constant air flow. Therefore, fuel supply needs to be cleaned... then you will run happy!!
-Jim
Posted on Oct 23, 2009
bbreton
  • 437 Answers
SOURCE: My Homelite mightylite blower vac starts but won't
The unit is under warranty. The person you talked to must be new. Find a warranty service center in your area. Take your receipt with you and they should be able to take care of it for you.
Good Day
Posted on Dec 14, 2009
SOURCE: Homelite bp250/170mph leaf blower will not idle.
small gas leak when running
Posted on Dec 24, 2009
  • 3 Answers
SOURCE: Looking for a owner manual for a homelite BP250
www.homelite.com
1.800.242.4672
they are less than a couple dollars.
Posted on Apr 30, 2010
SOURCE: wont idle have to run on 1/2 choke
yes, i have one myself. you must adjust the carb. there should be two screws to adjust the gas and air flow. try adjusting them to the right, both of thlem
Posted on Jun 28, 2010
I have the MightyLite 26bv....will only run at half choke. When turn knob to run, it dies. Does not reach full power ever.
The parts inside the carburetor need to be replaced (gasket and diaphragm kit) and/or the L and H screws need to be adjusted on the carb. Try grasping and turning the L mixture screw on the carburetor (one closest to engine) about 1/8 to 1/4 of a turn counterclockwise.
Jul 01, 2011 | Homelite Consumer Products MightyLite...
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My homelite string trimmmer will not run when choke is run position. it will run, but not at full throtle, when choke is set between full choke and half-choke.
you've got a fuel system issue , most likely carb problem, if this a newer trimmer it will likely need the carburetor replaced or adjusted, also check for cracking fuel lines or signs of old fuel varnish in the tank
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
Wont idle have to run on 1/2 choke
May 15, 2010 | Homelite Consumer Products MightyLite...
Cranks up runs few seconds ccuts off run half... on choke new gas lines
Make sure the muffler is not plugged. Sounds like the pump section of the carburetor is not working. Remove the carburetor and disassemble it. Keep track of where things go. Re-kit it if the rubber diaphragm is stiff or damaged. Same with the valves and diaphragm in the pumper section. Soak only the metal parts in spray carburetor cleaner, then blow out all passages with compressed air. Reinstall the H and L needles CW to stops (lightly), then turn both CCW 1-1/2 turns. The engine should start and run with these settings. Allow the engine to warm up, then apply full throttle and adjust H needle for fastest speed, but 4-stroking--which smooths out immediately when trying a cut. Next, adjust L needle for smooth idle, bur rich enough to allow the engine to follow the throttle without gasping. Then adjust the idle speed screw to just allow the chain to stop turning. Make sure the air cleaner is in good condition.
Sep 02, 2009 | Garden
Gas leaf blower runs at half speed
First you will have to get a carburetor kit ,it consists of diaprams and inlet needle,you then remove the two srews that hold carburetor on the engine and remove gas lines,also the throttle cable remove screws that hold ends of carburetor on under these you will find the diaphrams and needle remove these be carefull not to loose the little spring under the needle lever.
!get you a can of carburetor cleaner and spray carburetor the blow it out with air you will notice little jets in carburetor that have to be clean use a wire from a bread tie to clean them out install new gaskets and diaprams in same position you took old ones off.you can also look at carburetor to see what kind it is walbor,zama,tilloson? type the name in google search and can get a diagram of carburetor if you loose your place,or just ask me.
May 15, 2009 | Homelite Consumer Products MightyLite...
Mightylite 26 leaf blower
have you tried changing the air filter and spark plug?
Nov 20, 2008 | Homelite Consumer Products MightyLite...
Homelite Gas Fuel Cap  Blower Bp250 Bp250i Bp30185 Bx90 Logo
135 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
