Question about Kitchen Ranges
I have a commercial Lochinavar copper fin z pool heater. In the past few days it shuts down showing code "E03" the heater is approx. 10 months old. What is the error code saying? Where can I purchase partss in Tucson AZ? Tim Fudge (520) 235-3462
guide2u
  • 461 Answers
SOURCE: DP-1820 error code
it does not appear in the user guide information that I have however, if you describe the problem that you are facing currently i might be able to point out to the right direction...
Posted on Sep 21, 2007
  • 126 Answers
SOURCE: Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Posted on Dec 13, 2007
ceck
SOURCE: NEC LT260's shutting down
I think I have solved this issue with my LT260K. I too had shut downs after 5 minutes of operation. It roughly followed a replacement of the bulb. I repaired stereos in the 70's and 80's, so I was not going to let the projector get the best of me without a tear down. I cleaned the fan blades, checked their operation. I checked the continuity of the thermostat on top of the bulb bracket, but found no apparent failures. I did find a possible loose connector in the middle of the projector as it seemed loose as I was disassembling the unit (see 1st picture). 7c58d4f.jpgThen I checked for cracked or burned areas on the PCB's. During this I scanned as much of the solder joints as I could. In the 'old' days, the power supply area could get hot and make cold solder joints. I found what appeared to be heat damaged solder joints on the auxiliary power board (Lamp power). This is the one that is back right of the projector opposite the power switch. It is a vertical board that solders into the horizontal bulb power board. I resoldered these and I am up and running. USE CAUTION, I would leave this to a trained professional to repair. This requires major disassembly.18d84c8.jpg
Posted on Jul 16, 2009
  • 990 Answers
SOURCE: error code e03
This is a code for a thermal fuse open. A thermal fuse is a saftey device I always call a wax switch, It's a switch held closed by wax and if it get's too hot the wax melts and the switch opens shuting the heater down.
Changing this out will not fix the problem. It's job is to keep the heat source from hurting the heater. In other words you have fire backing up into the heater outside the fire box. This can be a fan problem or sometyhing as bad as a broken firebox. You will probally need to get a repairman involved at least to find the problem. Good luck.
Posted on Feb 17, 2010
  • 760 Answers
SOURCE: Pool heater shuts off after a few second
You didn't indicate your exact model. There are different versions of the H200 series. If it is milivolt then there is no electric, Must have correct milli-volt pilot generator. If it's electronic, check the air flow pressure switch on the combustion air.
Posted on Jul 18, 2010
Where is the heat exchange in a rheem pool heater located ?
The PVC plumbing is hooked into the front header, the front header is attached to the heat exchanger. The heat exchanger looks like copper finned tubes with a steel plate on each end. You need to disassemble heater working from top down to get to the exchanger. A skilled tech can replace an exchanger in under one hour service call.
Aug 19, 2014 | Rheem 266K to 399K BTU Swimming Pool...
Why do i continue to show low salt?
I do have the same problem every few days all I just discover is that I remove the cell tube and with the help of a long thin knife I clean the surface of the copper cell both in between and outsides. There is always dry salt on the surfaces and after the cleaning the sensor reading is in acceptable level so the chlorinator is working perfect without any 91 massage. To work it every day in order to avoid this happens very often and of course every time you hear the beap sound you have to repeat the scrutching and cleaning with the nife,
Jun 13, 2014 | Intex Automatic Salt Water System for ...
What does this lock out code adcerr s6 s8 mean?
lock out means tried 3 times and failed check gas pressure and breakers
May 27, 2014 | Lochinvar CHN651 650000 BTU Copper-Fin II...
Hayward H400FDN will not stay lit - Brand New install - NO Fault codes.
make sure wiring is correct especially if wired 120 volt read instructions inside panel
Jan 28, 2014 | Hayward Industrial Products H400FDN...
What does error code r =8 at startup mean? Turned heater on for first time this year. Opened gas valve at tank and shut-off at heater. Pump is running. Turned 220 v breaker on in box and "spa on"...
Mike, I have found what I believe is the correct manual for your heater at http://www.pool-heaters.com/pdf/Pentair-Maxetherm_manual.pdf. I couldn't find an error code list in the manual but I might have missed it. If you call the the StaRite technical support line at 888-782-7483 they should be able to help youfigure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Error code e03
Feb 17, 2010 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Jul 05, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Kitchen Ranges Logo
23 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
