Question about Protec Microsystems Bytelan KVM/4 KVM Switch
Want to know hot key combination to switch ports from keyboard.
Got this unit at an auction with no docs.Works good and switches ports using front panel pushbutton,but for convinience, hot key switch is the ticket!!
Would be very gratefull for any fothcoming info.
Txs.
Press and release CTRL-ALT-SHIFT
Press and release Machine # (1 - 4)
Press and release ENTER
or
Press and release 9 (This puts you into Prev/Next Mode)
Prev = Left Shift - Next = Right Shift
Press and release space bar to exit Prev/Next Mode.
Posted on Feb 09, 2009
What is the hot key
I really wanted to love this switch. However, the best thing that I can say about it is...it works as advertised. Whoa, so what's the problem? Well, the switch has two major problems. The first isn't really Linksys' problem; it's apparent on other manufacturer's switches as well. The switch doesn't support 4th mouse buttons or scroll wheels*. Once the mouse is connected to the switch, those functions are disabled. The Belkin literature (for the OmniView mentioned above) even goes as far to say you should use generic 2-button mouse drivers! While it's not the end of the world, it's pretty frustrating to lose those features.
The other problem, however, renders the switch useless for me. Instead of having to reach for the button on the switch to change PC's, they have built in a keyboard shortcut. Sounds like a great feature right? It would be except that they have made the keyboard shortcut CTRL CTRL. If you hit the CTRL key twice quickly, you will change PC's. The CTRL key?? Why would they choose a key that is used often? I use the CTRL key for firing during games. Imagine what happens when you fire rapidly. Yes, you get the strobe effect as you switch back and forth between PC's! Also, if you use the CTRL key for editing (CTRL C, CTRL V, etc.), an inadvertant double stroke on the CTRL key will switch PC's. This is unbelievable. Unfortunately, the hotkey can neither be changed nor disabled. In contrast, while it is also unchangeable, the Belkin unit uses the Scroll Lock key. This is a much more logical choice because the Scroll Lock is basically obsolete in today's computing experience.
This is some hope, though, because their 4-port switch uses a a keyboard combination of ALT CTRL SHIFT # (where #=1,2,3 and 4). While it is a little more cumbersome, it prevents accidental switching of PC's. Also, the 4-port version has Auto-Scan, which allows you to automatically cycle between your PC's. That option is not available on the 2-port version.
I recommend getting the switch kit instead of just the switch alone. While it doesn't cost a lot more ($18), the SuperVGA cables are worth the price. They are normally $23 each! I tried standard VGA cables on the Belkin switch and the signal degradation was unacceptable. hope that you get the information u need
Aug 31, 2010 | Linksys ProConnect 2-port KVM Switch
I am looking for the hotkey combination for our HP 336044-b21 KVM switch from a iogear KVM?
IOGEAR KVM switches uses Scroll Lock for the hot key. The models of IOGEAR KVM switches starts the letters "GCS". I don't think that your HP 336044-b21 came from IOGEAR.
Anyway, if that's an IOGEAR KVM switch, you may quickly press Scroll Lock twice + Enter (for two port KVM).
Scroll Lock twice + port # + Enter (for 4 port, or 8 port KVM).
NOTE: You need to verify the brand of your KVM switch by referring to the user manual of it.
Thank you and good luck!
May 20, 2010 | HP 336044-B21 8-port KVM Switch
I just bought a 2-port kvm switch model no. F1DJ102P (P81551). Can you please tell me the keyboard "hot key" to switch from 1 computer to the other without pressing the button on the KVM unit itself?...
You can conveniently change ports on the Switch through a keyboard command
sequence using the “SCROLL LOCK” key and up and down arrow keys. To send
commands to the Switch, press the “SCROLL LOCK” key twice within two seconds.
You will hear a beep for confirmation. Then you can press the up or down arrow
keys to switch between ports.
Apr 09, 2010 | Computers & Internet
Not working
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: http://www.aten.com/download/download.php#productGuide (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Oct 03, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Can't switch ports using PC keyboard
Make sure that your keyboard is connected to the keyboard port of the switch. The USB ports on the switch has pictures that indicates where the keyboard and mouse should be connected.
The hotkey combination is CTRL + ALT + SHIFT + Port no.(1,2,3 or 4) + ENTER
Note: "tap the keys one at a time and not at the same time"
Jun 17, 2009 | IOGear USB gcs1734 4-port KVM Switch
KVM hotkey
Hold down the Scroll Lock key for several seconds. The switch should beep briefly and blink. Hit either the "1" or "2" key on your keyboard to switch to the corresponding computer connection.
Jun 23, 2008 | LinxCel PS-121D 2 Port PS2 KVM Switch
KVM 2 PORT SWITCH
Yes try uninstaling the kvm switch reboot pc's install the kvm again and try another key and see if that works
Jan 29, 2008 | JustCom jc-102cp 2-port KVM Switch
Hotkey mode
This just worked for me. Using your PC keyboard, boot up to the PC first and then power up your mac. Hit the scroll lock twice and IMMEDIATELY hit enter. You have to go fast- click-click-click with no hesitation and it works great. I still can't toggle the hot keys to set up my mac keyboard, which I prefer using, but I'm assuming it takes the "right" timing on the keys. I'll keep trying.
Oct 23, 2007 | IOGear GCS632U 2-port KVM Switch
CS62U 2 Port USBKVM Switch not switching
Are you sure, the usb cable belonging to the keyboard is plugged in the appropriate slot?
I have a wireless keyboard/mouse, so I have only 1 usb cable going into the switch. The first time, is plugged it into the slot of the mouse, and the switch did not work, so I plugged the cable in the other slot, and now everything works properly.
May 29, 2007 | Altusen Aten CS62U-2 Port USB KVM Switch
Dakota Scout kvm
I use one of these, and hotkey sequence is . Where is A,B,C or D.
Jan 02, 2007 | Dakota Scout KVM Switch
Protec Microsystems Bytelan KVM/4 KVM Switch Logo
419 people viewed this question
Top Protec Microsystems Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Protec Microsystems Computer and Internet Expert? Answer questions, earn points and help others
