Xerox c123 error 116-389 problem - Office Equipment & Supplies
  • 4,338 Answers
The error 116-389 signifies "'read-only memory not install ", or read-only memory not recognized.
Reseat the memory.
if it does not clear, your memory is bad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on May 21, 2011
Showing error 047-212
That is an OCT2 error, exit error. If it happens every time or right when you turn on the machine it's either a defective exit sensor or exit pwb. The error itself indicates that the paper is late to get to that sensor so could also be from the registration section below, possibly a registration clutch slipping. Look at the print on the page and see if it's centered correctly.
Feb 29, 2016 | Xerox CopyCentre C123 Copier
How do I fix error code 091-914 for my Xerox C123 copier?
If you installed the correct drum, then the Crum PWB 160K95830 might be bad. This reads the chip on the drum.
If not, then you might be installing a "metered" cost-per-page version. Double check the part numbers.
Oct 20, 2015 | Xerox CopyCentre C123 Copier
How do I turn off copy-card default on xerox copycenter c123
http://www.support.xerox.com/support/copycentre-c123-c128/support/enus.html
This is how to turn off Auditron but this is the same menu as "foreign interface device" or copy card.
Jan 17, 2014 | Xerox CopyCentre C123 Copier
How do I do a password for the machine Xerox CopyCentre C128
Click on the link below and select to view the Xerox CopyCentre C128 owners manualm inside the manual will show you how to set the password
http://www.support.xerox.com/support/copycentre-c123-c128/documentation/enus.html
Dec 19, 2010 | Xerox CopyCentre C128 Black and White...
CopyCentre C123 Copier Copier: CODE 116-331...
It may be a defective Main System Controller board 160K91660 or Hard Drive 960K01120.
There is a diagnostic which requires the Xerox Technician's Laptop to test the Hard Drive.
You might get lucky just reseating the Hard Drive.
Whit
Item, Inc.
May 17, 2010 | Xerox CopyCentre C123 Copier Copier
My Xerox Copy centre C123 shows error code 124-315 pls help
Thats a weird one. The machine is detecting the wrong speeds.
Try this.
  1. Enter Diagnostic Mode ( UI Diagnostic Mode).
  2. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
  3. Press buttons 6, 7, 8, and 9 on keypad and press Confirm.
  4. Press the Log In/Out button (button with Key symbol) on the Control Panel.
  5. Select System Settings.
  6. Select Common Settings.
  7. Select Maintenance/Diagnostics.
Then look at these 3 locations and see if they match, If they do not set them to match the machine speed.
  • [700-600]
  • [700-601]
  • [700-602]
Feb 11, 2010 | Xerox CopyCentre C123 Copier
Gives an error code 062-277
You will have to call in a xerox tech, it seems that one of the boards on the scanner is u\s
Apr 13, 2009 | Xerox CopyCentre C123 Black and White...
Schematic of the Xerox XC865
google The Parts Drop, Give them a call, ask for Britt he can help you most likely.
Mar 10, 2009 | Xerox CopyCentre C123 Copier
Canon ImageClass MF6500 Message on machine ''Download Standby''
My Xerox copy centre C123 shows error code 124-315
and the message says to Switch off the machine and turn it on
Feb 16, 2009 | Canon Office Equipment & Supplies
Copying with a copycentre 255
Go to www.xerox.com , on the home page click Support and Drivers.
IN the search where it asks for a product name or number type in 255.
Then select the Copycenter 255 Documentation.
Then select either the QUick reference guide, which is most likely all you need. or download the training and information program.
Jan 01, 2009 | Xerox CopyCentre C123 Copier
587 people viewed this question
k24674
jasbo
jasbo
