Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
My Frigidaire Electrolux dishwasher, model # FDB2310LCC2 is blinking "CL" although the door is closed. What can I do to correct this?
aborcass
  • 2651 Answers
SOURCE: Frigidaire Dishwasher CL error light
sound as if your having an issue with the latch not closing properly( switches not making contact inside) yo can take apart, requires dropping the front panels and checking the switches, or replace the entire switch costs about 60 bucks part number 154529403 (black handle)
Posted on Mar 24, 2008
ginko
  • 19396 Answers
SOURCE: Electorlux dishwasher flashing CL
Error CL means that the child lock had been activated.
To unlock the machine you should put your finger up inside the handle and locate a slider switch, then push the switch to to the left side.
Posted on Oct 24, 2008
Illeagle
  • 525 Answers
SOURCE: Need new spray arm for my dishwasher
Try this link to identify which wash arm you need.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5148522
Posted on Jul 21, 2009
SOURCE: error message ''CL'' on electrolux dx302w dishwasher
The label says this is the child lock. You can cancel it by holding the two buttons (program & start/pause) simultaneously for 5 seconds. i tried it on mine & it seems to work.
Chris
Posted on Sep 08, 2009
  • 28 Answers
SOURCE: Dishwasher wont drain
Look for food in sump and drain hose, if clear may need drain pump
Posted on Mar 03, 2010
I have a Frigidaire dishwasher model # FDB2415LFSO with a blinking CL code. When I try the normal wash cycle button the drain pump runs and the CL light blinks continuously and nothing more happens. The...
Good Afternoon friend, thank you for your post!
Based off what you have described you have performed multiple tests to your Frigidaire dishwasher and it continues to display a "CL". That code does stand for close door which can mean that the door switch is sensing it is opened. For this error code it could be a possible problem with your door switch or main control. I understand you stated that the control did not appear to have a burn inside of it so it is easy to assume that the door latch could be the issue. Remember if you are not a professional technician this could be the start of unnecessary part purchases. I hope this information is helpful to some degree. -Matt
Feb 24, 2015 | Frigidaire Dishwashers
Why won't my dishwasher start?
Thank you for your inquiry, friend!
Based off the information you have provided "CL" stands for close door. If you continue to experience an issue with the "CL" error code I would recommend having a professional come out to your home and diagnose your appliance. "CL" could be a problem within your door switch or main control board. Hopefully this is helpful. -Matt
Aug 28, 2014 | Electrolux Dishwashers
CL trouble light flashing
If you reset the unit from the household circuit breaker and it doesn't change, then contact a professional to have the main control board repaired.
Aug 19, 2012 | Electrolux Frigidaire Professional Series...
Our dishwasher is blinking CL - i think this means 'Close'... Even when the door is properly closed, it blinks CL and won't start!! Help!
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Mar 24, 2011 | Frigidaire Professional Series 24 in....
Flashes "CL" to close door when it is closed and won't start
The door switch has failed. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the process will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
May 21, 2010 | Frigidaire Dishwashers
Mar 03, 2010 | Dishwashers
Frigidaire pld3460rdc1 the dishwasher flashed CL when the door is closed.
The CL is letting you know that the door was closed. If it continues to show CL it means you need to close and latch before the cycle will run. If it just flashes your okay.
Mar 10, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Oct 24, 2008 | Frigidaire 24 in. FDB2321REC Stainless...
Mar 24, 2008 | Dishwashers
Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Mar 14, 2008 | Dishwashers
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
157 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
