Question about Fuji Photography
! Protected card reads on my screen when I turn on camera..I tried taking card out several times and put back in
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on May 21, 2011
Canon 60d card write protected
This error is more common then you think.Since you tried most things, I only ask you to do only one thing. AFTER you saved the pictures on the card, just do a basic format (low level) in the camera. Just using the menu of the camera. You don't have to believe me, but cards formatted in other EOS cameras, yes from the same brand, can cause problems. Let alone when the card is formatted in a computer. If one or more cards work fine after you formatted them, and only one won't work, please discard this one.
Let me know if this helps.
Success
Feb 27, 2014 | Canon Cameras
My screen says memory card is protected (reset switch on memory card)
Just turn off the camera and take out the memory card. Then just adjust the small tab located at the upper left side of the card to unprotect it. Then put back he card and turn on ye camera again. That's it!
Jun 27, 2011 | Cameras
My digital camera says card write protected. changes many memory cards still the camera says card protected i slide the switch of the mmc up and down the screen still says card protected and i can't take...
Hello ranmer 9960:
First lets try the card in your PC to make sure the card is working. If it is working in the PC then its probable that the camera is not reading the lock switch correctly. Lets try setting the protection lock switch on the card in between the locked and unlocked position. If that doesn't work then we can try putting some electrical tape (because its thicker than cellophane tape) over the lock switch on the card This may help your cameras lock switch reader function correctly. Make the piece of tape wide enough to cover the lock switch on the card but don't cover the copper contacts.
Try these suggestions and if it works then give the thumbs up a click.
If not we can try something else.
Your FixYa team member Peter N.
Mar 28, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
My phone is not reading my sd card. I have taken it out and put it back in several times but it keeps telling me that the sd card is ready to remove as soon as i turn it back on. I have tried mounting it...
just another memory card in your phone.....if your mobile is getting fault means check whether your memory card is protected by password or not....
Jan 12, 2011 | Cell Phones
Fujifilm FinePix Z20fd protected card??
The memory card should have a little switch on it, try it in the other position. It is a safety lock to stop it getting wiped.
Feb 13, 2009 | Fuji Finepix Z20fd Digital Camera
Camera says card write protected
I just figured it out- on my memory card there's a small "switch" on the left hand side that you can slide up and down. Make sure that this is up the top, not down towards where it says Lock. If it's down, this makes the card Write Protected.
Nov 27, 2008 | Canon EOS Rebel XSi Digital Camera
SD PROTECTED keeps on screen. Can't use an SD card. How do I take the SD protection off ? Thanks, Bill
just check your sd card lock key... there is a small swith on the left side of moemory card; if if it is in down position, it's protected. so turn it to un protected mode. I hope this helps...
Oct 31, 2008 | Cameras
Card format problems
The first thing you will have to check the card. There is slot on the card that contains a switch. This will lock the card so that it is write-protected. This will cause the unsupported card error.
If the card looks fine, try a card reader just to confirm that the card has not been corrupted.
If the card is functional and you can read its contents from the PC or another SD-slot device, then the issue is your camera. The slot contains thin copper prongs that comes in contact the copper surface on the back of the SD card. If the prongs are bent or damage, then the camera cannot read your card.
Aug 27, 2008 | HP Photosmart M527 Digital Camera
How to unprotect the memory card
the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
May 18, 2008 | Microtek Take-it MV320 Digital Camera
Photography Logo
52 people viewed this question
Top Fuji Photography Experts
TC CAMERA REPAIR.Com...
pontelemon
pontelemon
Jax Planet
Jax Planet
Are you a Fuji Photography Expert? Answer questions, earn points and help others
