Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
I have a Kenmore 116. 25513506 and sometimes the bags I've been using --5505--tear when I put them in. What am I doing wrong?
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
Replacing belt
Hello Cheryl,
Please see detail instructions here.
Good Luck,
Rocky
Nov 15, 2011 | Kirby Ultimate G Bagged Upright Vacuum
It's 5 years old and I vacuum twice a week about 900 sq ft. It is starting to smoke and the belt sounds like it's working overtime. The hose is fine. The bag is continuing to fill up. The floor...
Make sure that the dirt bag is empty and that the motor bearings are good. Also check for any debris that may be gumming up motor bearings and forcing it to run slow.
You also can check out the motor brushes and replace them.
Mar 22, 2017 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore Powermate power head not working
I've got the same problem. Try checking out the electrical connection where the hose attaches to the canister. The hot male terminal is corroded and the female socket is burned out. Its an unfortunate design flaw that every time you open the vacuum to replace the bag the electrical connection disconnects and reconnects. Not sure if I can find replacement parts for a 10 year old vacuum or if a home-made re-wiring job is in order. Will find out tomorrow.
May 30, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
Tearing bags very frequently. This vacuum is used by three different professional janitors, and all have the same problem. The bag tears or pulls away from the lip very often.
We don't see Oreck problems very often on these pages, probably because their essential simplicity leaves very little that can possibly go wrong. However, your remark that this machine is used by professional janitors leaves me wondering if whoever made the purchasing decision took into account the type of use it would get. You may need a machine that's better suited to the job.
Jul 16, 2009 | Oreck XL2000 Bagged Upright Vacuum
DUST NOT COLLECTING IN THE DUST BAG
sounds like the bag if full and the is coming out from around the bag.make sure the bag is in correctly and tight
Jan 07, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore 23613
if it smells like burnt plastic it is something wrong with the motor part, but if it is a wet dog,burnt hair gross kinda smell it cool change the bag and buy deoderizer tablet to put under bag kinda like a airfreshener. if it dont work like it used too not picken up like should something wrong
hope that helps,
Dec 29, 2007 | Kenmore 22085 Bagged Canister Vacuum
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
56 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
