Where can i find a wiring diagram for a rudd air handler UHSA-HM3017JA
    Sergeant:
    Champion:
  • 229 Answers
Your going to have trouble getting a diagram for that air handler. tell me what it is doing maybe I can help you out.
Posted on May 21, 2011
Need wire diagram from T-stat to Air-Handler then cond unit
green goes to g on air-handler,white goes to w on air-handler yellow goes to outside condensor, red from air-handler goes to rh-rc on thermostat, whire off c on air-handler goes to outside condensor.
May 13, 2014 | Ruud Heating & Cooling
My customer has a Rudd Model UBHA-14A00NFAA air handler. I have replaced the 24 volt transformer twice and am about to install a third one. Initially it was suggested to me that the transformer in the...
John from one service man to another, most of the time I have seen that many transformers fail is when there is bare wires touching somewhere from the outdoor unit to the air handler. This cause a small short in the circuit. Usually its when there is a crawl space under the house or even when the wiring is up in the attic. I have seen birds, squirrels, dogs and even rats chew thru thermostat wire. Hope this helps you . Have you thought about putting a small 5 amp fuse in series with "C" on the thermostat?
Jul 11, 2011 | Ruud Heating & Cooling
WIRING THE THERMOSTAT TO AC UNIT THEN FROM THE UNIT TO HANDLER
Generally, you would go from the thermostat to the air handler, and then, from the air handler to the outdoor unit. I don't know if you have a heat pump or not, so I will give you a simple diagram and you can contact me if you need more.
Thermostat : Y G R W and sometimes C
Air handler: Y G R W and C
Outdoor unit: two wires connecting to the contactor ( not heat pump)
Thermostat; Y--------------Y(air handler cooling)------------------one side of contactor, outdoor unit
G-------------G (air handler, fan)
R--------------R (air handler ,hot)
W-------------W (air handler, heat)
C--------------C (air handler, common)------------other side of contactor, outdoor unit
This is a typical wiring diagram. Just contact me if you have something different. Hope this helps. Stay cool. mark
Jul 10, 2011 | Heating & Cooling
What is the size of coil in air handler is it 3 1/2 ton and believe that rudd only made 2 ,3 , 4, 5 , ton coil is this right
It is a 3.5 ton air handler and without knowing for sure about Rudd only making those sizes which they should, they more than likely would have gone up to a 4ton coil. One way to cross check this, is to see what ton the condenser outside says it is. If you have a 4ton condenser, then you should have a 3.5 to 4 ton coil, either being okay. What you don't want, is a 3 ton coil and a 4 ton condenser and so on. A half ton isn't going to be a problem regardless, but if anything, you can always take the measurements of the coil if you are trying to replace it.
Feb 03, 2010 | Ruud UAMB042 Air Conditioner
I have a Rudd Achiever 14 and I want to know if
Take the front panel off the air handler and look for a heat element. You should notice controls and relays with larger wiring to it. It may not have any heat but you can add it.
Jan 05, 2010 | Ruud Handler Air Conditioner
Rudd achiever serie. where do the 24 volt wires go to on the air handler.
The two wires from condensing unit go yellow or y from Tstat and theother wire goes brown if it is a Rudd or Rheem. Red from Air HAndler goes to Tstat R Green to Tstat G white to w. If it is digital tstat brown goes to C.
Jun 04, 2009 | Ruud UAMB Air Conditioner
Wiring match-up
If this is a standard heat cool unit. You have a tstat with rygwcob. Just color code the wire to the unit. Some air handlers such as Rheem and carrier use different collors for there common Carrier black Rheem or Rudd Brown. Two wires that go outside use yellow blue. Yellow to Y fron Tsta and blue to common or blue,blavk or brown.or C
May 30, 2009 | Heating & Cooling
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Sep 02, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
244 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
