Question about Polaris Pb4 - 60 Booster Pump
My Polaris PB4-60 was installed last August brand new. It completed the season working fine. When the pool was opened in the spring the pump is dead, nothing happens when it is switched on. I checked the breaker, the wiring and the ground wire, all are installed properly? What do I check next?
    President:
  • 1,902 Answers
Sounds like it is popping a safety switch or the other issue is that it is getting wet internally from the moisture in the air and is causing the pump to fail, It should technically still be under warranty, I would call the company that replaced the pump or that you bought the pump from and let them know what is going on.
Posted on May 21, 2011
Brand new motor replaced old pb4. After installation it just hums and does not pump. Before installation it works fine without water going through? Any body know what is wrong?
Double check the wiring installation. One wire wrong will stop it. Don't let it hum! Compare old motor to new, are they the same voltage? Can you rotate the motor by hand? It should be free.
Oct 26, 2013 | Polaris Pb460 Polaris Booster Pump...
Polaris Booster Pump Brand New keeps shutting off
if wired 120 check side of motor rewire for low voltage
Jul 22, 2013 | Polaris Pb4 - 60 Booster Pump
Did rabbit break my polaris pb4-60 booster pump?
coincidence motor overheating replace motor or pump
Jul 20, 2012 | Polaris Pb4 - 60 Booster Pump
My pool is losing water when a Polaris 380 is running off a booser pump
plug both sides of Polaris hoses one at wall and one at Polaris if stops leak in Polaris line
Jun 08, 2012 | Polaris 380 In Ground Pool Cleaner
I hooked up a new Polaris 280 pool cleaner to replace my Arneson Navigator and it doesn't move.
I would first take it out of the water and check for proper wheel RPM. If it is less than 28 RPM or you are getting no movement at all, it is going to be a problem with the power source. It is likely going to be that your booster pump is missing, malfunctioning, or is not installed properly on the pool cleaner. There are a few other things to check. Clean the skimmer, filter and pump basket, clearing any debris that restricts water flow. Check the hoses, connections and swivels for leaks. Try removing the blue restrictor disk from the UWF or if an adjustable gate valve is installed on the booster pump or cleaner line, open it completely so water can flow freely.
Jul 20, 2011 | Polaris VacSweep 280 Pool Cleaner with...
Had Polaris rebuilt last summer. Then wouldn't
Thank you for posting your question here on Fixya.com.
Have you cleaned or replaced the in-line filter found at the wall socket? How about the pressure valve found just after the wall socket...is it fully open, possibly allowing too much water to bypass the cleaner and return to the pool?
How about the main filter? If overall system flow is reduced because of a dirty main filter the booster pump would be 'boosting' lower than normal pressure so the net result at the cleaner is reduced as well. A cartridge filter is especially problematic here. It can look clean after rinsing it but after enough use the element needs to be replaced to restore original system flow.
Are there multiple return paths for water back to the pool that have valves? Can you throttle down a return to, say a spa for example, to force more water to the dedicated line for the cleaner?
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 18, 2010 | Polaris Pb4 - 60 Booster Pump
I have a Polaris LR51044 pump that is not working. When I turn it on it "hums" but won't pump water. I live in Baton Rouge, La. and we have had freezing or below freezing weather for the last 2 days. The...
Usually when a polaris booster pump hums it means 1 of 2 things; either the starting capacitor needs to be replaced (its located under the black hump on top of the motor) or the pump is bad. Most likely the starting capacitor needs to be replaces. This is where you should start since the capcitor is only $20-$30. Get a new capacitor from a local pool store, shut the power off to the motor, remove two screws on each side of black hump on top of motor, remove two wires from starting capacitor and install wires on new capacitor, replace cover and turn the pump on. If that doesn't work you will need to replace the motor.
Jan 09, 2010 | Polaris Pb4 - 60 Booster Pump
Polaris 280 - tank track keeps coming off
I battled with the track falling off for over a season. The pool guys said they fixed it. Tried the previous solution to adjust middle wheel but no luck. My solution was to remove the left wheel and the tank (to get to the screws). The wheel mount allows for minor adjustment but it is also reversible. Turn the mount around and this will extend the wheel base much more. Mine ran for several hours after doing this and so far the track stays on.
Dec 28, 2008 | Polaris 280 In - Ground Pool Cleaner with...
Polaris Pb4 - 60 Booster Pump Logo
220 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
