Question about ViewSonic N3752w 37 in. LCD TV
Power led continous blinking - ViewSonic N3752w 37 in. LCD TV
    Genius:
  • 1,112 Answers
HI:
You will need to change the power supply, in this unit, You just may get lucky and find bad capacitors on the power supply that you can change to restore the unit to operational mode.look capacitors that are buldging on its tops.
Posted on May 21, 2011
My tcl led TV picture blinks continously
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 19, 2016 | Televison & Video
Power LED continously blinks
Main system control IC fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 30, 2014 | Televison & Video
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
Had continous red blinks on lamp led replaced lamp and ballast, now have 5 blinks on power led still no picture or sound
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Sony KDF-E55A20 55 in. LCD Television
All leds are blinking continously in Epson stylus cx 5500 printe
turn on/off, unplug, plug in2_bing.gif, should reset configs.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Epson Stylus CX5400 All-In-One InkJet...
I hv sanyo plcxu48 , its power on led continously blinks in red ,projector not getting on at all, pls advise
if you count the number of blinks and time between them and repost I will try and sort out the problem, the blinking is normally indicative of a fault
Dec 17, 2009 | Sanyo PLC-WXU30 Projector
Switch led is continously blinking in green colour
Sounds like you don't have a stable connection. Try shutting down PC, and disconnect the monitor, and reconnect it, and turn PC back on, then turn the monitor on...
May 14, 2009 | Hitachi CM621F (White) 17 in.CRT...
Sony Fd Trinitron KV-32FX68E, stanby led blinks twice
odds are power supply module 150 200 repair
Dec 01, 2008 | Televison & Video
Sony kv-32fq86e 16 blinks
If red led blinks continously , please check horizontal o/p or EHT screen control reduce and check for power on
sam
Apr 18, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony trinitron tv
If you have sound but no picture it means that your power supply and tuner are working correctly. The number of times the timer LED blinks is the code for the problem with the picture. The computer will stop the picture and blink the timer LED if the vertical circuit stops working, if the picture tube is too weak or if the horizontal sweep has stopped. The set should be serviced by a qualified tech familiar with Sony sets.
Sep 03, 2007 | Sony WEGA KD-34XBR970 34" TV
Open Questions:
See all ViewSonic N3752w 37 in. LCD TV Questions
ViewSonic N3752w 37 in. LCD TV Logo
118 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
