Question about Pentair Minimax NT Heater
I have a Pentair minimax 250k electronic. Opened pool today and when I turned power on to the heater, it won't get through startup sequence. Dashed lines flash, then 888 and service light comes on. No error codes. Setting the heater temp does nothing because it goes right back to flashing the --- then 888 (with service light). No error code given. I called a pool repair guy and he immediately said its the blower that needs to be replaced, but I don't have the pool temp set for the blower to even attempt to turn on. I did try, but same startup sequence bouncing.
    Problem Solver:
  • 13 Answers
Most of the time I have found the problem to be the thermistor. It is located on the water manifold of the heater. Usually the panel lights, flashes then to 888 and back to dashed lines. SW light is green, and service light is red. It costs 25 to 45 dollars, and takes 5 minutes to repair. New thermistor looks identical to old so replacing it is very easy.
thanks please let me know if this was helpful
Posted on Jun 19, 2011
How to replace a safety shutoff in my pool heater?
turn gas and power off. disconnect both wires from safety switch
Aug 30, 2013 | Pentair 250k Minimax Ch Lp Mv Heater
Pentair 250 pool heater
check gas pressure and when it goes out check voltage from transformer
May 28, 2013 | Pentair 250k Minimax Ch Ng Mv Heater
Pentair MiniMax CH 200 won't shut off
check temp sensor on control if one attached if no control check heater temp sensor
Jun 13, 2012 | Pentair Minimax CH Heater
Pentair Minimax NT 250k - ERR blinks 3 times
check pressure switch or tubing to it then gas and ignitor
Mar 22, 2012 | Pentair Minimax NT Heater
Pentair pool heater won't lite. status light says ignition lock out. how do i fix it.
If you have a voltmeter and can follow diagnostic instructions over the phone you may be able to contact Pentair technical support and they may be able to walk you through the sequence. I hope this helps.
Aug 04, 2011 | Pentair Minimax NT Heater
I have a Pentair Minimax NT 250k electronic heater. Turned the heater on today and it does not get through startup sequence. It flashes - - -, then flashes 888 (with red service light), then back to - -...
I would say the problem is the thermistor. The board will light up, the SW switch is green, but you get a display that flashes dashed lines and then what looks like 888. That is a start up code. The thermistor is located on the side where the water enters the heater. There are two screws at the top of the side panel. Undo the screws and lift the panel off. The thermistor is a probe with 2 small wires coming out and lead to the control panel. It is a very simple fix and is usually the problem if you have not experienced any other issues. The part runs between 30 and 45 dollars. Most pool stores would carry this.
thanks let me know if that fixed the problem
May 21, 2011 | Pentair Minimax NT Heater
I have a Pentair MasterTemp Heater 250K BTU (i think) Turned on the spa the heat it today and lost all power to whole Pentair Intlitouch system. Reset system but now heater is showing Service Heater. AFS...
try cycling the power to the heater itself. Check for damage (pack rats, etc..). It sounds like you may have had a direct short. It could be a board problem or a transformer problem. If you're still getting the service heater light, check to see if any diagnostic LED is illuminated behind the board.
Dec 28, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Pentair minimax 250 leaks onto burner
Unfortunately it is usually caused by a bad heat exchanger. Not too expensive, but a dirty, time consuming job to replace.
Aug 09, 2009 | Pentair 250k Minimax Ch Lp Mv Heater
Pentair Minimax NT Heater Logo
290 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
