Question about Maytag Neptune MDG5500AW Gas Dryer
The dryer is taking hours to dry a load of towels. I cleaned the vent and it still is taking too long. Help?
    President:
  • 3,074 Answers
Disconnect the vent and feel the air flow out of the dryer, you may have to clean the inside of the dryer out, underneath the lint trap is a sensor that may have to be cleaned,also. Hope this helped Tim
Posted on May 21, 2011
Dryer not heating enought
The first thing you need to do is make sure your dryer vent hose is clean. An easy test (if you have a really long dryer vent run) is to unhook your dryer vent hose from the back of the dryer and just dry a load of towels like you normally would. If your towels are nice and dry when the cycle is complete, then you know your dryer hose vent is clogged somewhere down the line.
Oct 13, 2014 | Maytag Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Everythings dries fine in my Kenmore dryer except for towels. It takes 2+ hours to dry a load of towels. What could be the issue?
Make sure that the moist warm air from the dryer can escape from the room where the dryer is located and that the Lint filter is clean and, if fitted, the air control vent is fully open.
The dryer needs to get clean fresh air with little or no moisture tro work properly: opening window/door to let the excessive moist air escape will help.
Hope it helps!
Sep 23, 2011 | Dryers
It takes forever to dry a load of clothes. Drum
Have you checked your vent for blockage? Over time, lint build-up in the vent and in the back of the dryer makes your drying time longer and longer. Unplug the dryer, pull it out and disconnect the vent. Using a flashlight and a vacuum, clean out the back of the dryer that connects to the vent and the vent itself. If you have a long vent line, you'll need to find a away to clean it out to clear any blockage. I use a hand-held plumbers snake that rolls up and pulls out as much length as needed. Then spin it around in the vent to knock off lint attached inside the vent tube walls. It may be easier to do this from the outside, but you can do it from the inside too. Check your outside vent cap for blockage and make sure the vent flap outside is not stuck closed. Also make sure when you push the dryer back into place, that you don't squish the vent tube, if it is made of plastic or foil. After reconnecting the vent, turn on the dryer. The air flow may blow out the lint you have dislodged with the snake. Clean out as necessary at the outside vent. I have a long vent line on my dryer, so I have do this annually. This has helped shorten my dry time every time I do it. Of course, cleaning out the filter regularly, does help too. The more often you clean the filter, the less lint that will build up in the vent . Hope this helps. Douglas
Jul 17, 2010 | Maytag MED5600TQ Electric Dryer
Takes 4 hours to dry a load of towels. plenty of heat - just not drying
How damp are the towels? More moisture= more time to dry
Is the dryer full to the top with towels? There needs to be enough space to allow for air flow in and out.
Also check exhaust vent to make sure it is not blocked.
Oct 09, 2009 | Whirlpool GEW9250 Electric Dryer
It now takes 2 hours to dry towels
lets hit the eazy button first.dry a load with out the venting[wont hurt a thing]if ok its the house venting,if not dryer .GE is only brand that has two elements.so if not ge and heating element ok and its blockage in the dryer.hope that helps God bless ,tom
Jan 04, 2009 | Dryers
Kenmore elite smartheat quitpak electric dyer
try drying load with vent tube disconnected may get warm and dusty but if works ok recheck vent completely also be sure vent is not being flattened when dryer is pushed back to wall also remove lower panel(clips along top edge each corner about 3-4 inches in)remove blower housing 2-3 screws and clean housing
Dec 12, 2008 | Dryers
MY WHIRLPOOL FRONT LOAD DRYER TAKES 1.5 TO 2 HOURS TO DRY A LOAD OF TOWELS OR JEANS.
ck vent all the way to outside to verify vent problem try a load with vent disconnected may get a little warm and dusty but will prove vent issue
Nov 20, 2008 | Dryers
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
62 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
