Question about Western Digital Computers & Internet
My external hard drive wont load and when i go into 'computer' it crashes
  • Western Digital Master
  • 27,725 Answers
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Posted on May 21, 2011
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
Mar 13, 2017 | Compaq Mini 110c-1001NR Notebook
I cant open or format my hard disc
Try this method
Uninstall the hard disk
Connect it to the other system/laptop as external drive
Install data recovery software on system/laptop
Scan the external drive for recovery options available
Save the data you want to recover
You can download a good data recovery software from http://www.windowsdatarecovery.com/
Aug 16, 2011 | Computers & Internet
Dear Samsung my external is not access my files on the console and it gives an error that says 'the parameters are incorrect?
You may try asoftech data recovery which helped me before. You can download trial for free
http://www.asoftech.com/adr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Aug 15, 2011 | Samsung G3 Station 1.5TB USB 2.0 External...
I have the Buffalo HD-CX2 external hard drive and it was installed on my laptop, until it needed to be completely wiped out, and now I can't get it to install and I can't view my files on the...
you can try some data recovery software. You can see
It tells the steps how to perform data recovery.
If above does not work, you may have to format the external hard drive (use quick format), and then use above mentioned software to scan again the external hard drive and recover your files.
May 25, 2011 | Buffalo Tools HD-CX2.0TU2 2 TB USB 2.0...
Damage hard drive
If you've damaged your laptop's hard drive, there isn't too much you can do about the issue depending on the amount of damage. If it is only crashing, but still operable, you may just have enough time to save some of your information with an external hard drive or other form of data storage. Retrieve your preferred data storage device (an external hard drive would be the best choice in this situation) and try to save as much data from the broken hard drive by copying your data over to a backup folder on your external hard drive. You can find your external hard drive under "My Computer" once it has been plugged in. After you've saved your data, I would suggest buying a new hard drive for your laptop and replacing it carefully. Most laptops can be opened up from the bottom (DON'T undo any screws) and have their hard drives removed, so that you may be able to place in a new one. Be sure that you buy a compatible laptop hard drive, and not a larger hard drive meant for desktop computers.
May 06, 2011 | Computers & Internet
Extermal hard drive won't power up
Use this data recovery program called asoftech data recovery
http://download.cnet.com/Asoftech-Data-Recovery/3000-2248_4-75328850.html?part=dl-75328850&subj=dl&tag=button
You can find it in magazines or on a internet...
It is a simple, fast program which thorough scan the computer, which allows you to recover lost files
Do not use the machines to take more photos before you have recovered or is likely to override the old and losing it all ....
The program can also use it to retrieve other types of files such as music and video.
Apr 05, 2011 | Samsung G3 Station Desktop External Drive...
My hitachi external hard drive can't be found by my laptop
Remove it and install it into another computer to see what'll happen.
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it,you can recover data on it with data recovery program to avoid losing them.
I have succeed with Tenorshare data recovery. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash and 'not recognized' issue.You can get it here: http://www.any-data-recovery.com/index.htm
After you recover your data,you can format it to check out whether it can be fixed.
If the hard drive can't be detected,you can try this way.Put it in a zip-lock bag and put it in the freezer overnight. Then while it's still cold plug it into the computer and you may be able to view it in 'my computer'. And run the recovery program to recover your data on it.
If it fails, you will have to go to a recovery office but let's hope not because it will cost you a lot of money and whether they can recover data is not guaranteed.
This article will help.
How To Recover Lost Data From Crashed Hard Drive?
http://tenorsharedatarecovery.blogspot.com/how-to-recover-lost-data-from-crashed.html
Feb 13, 2011 | Hitachi 500GB External USB 2.0 Hard Drive
My desktop crashed. I lost everything on it. I thought I downloaded some informatin on my Seagate Externa harddrive, however, I am having problems connecting to other computers to see if any information is...
External hard drives are plug and play, the drivers are build into windows.
IF the hard drive was connected when your computed crashed, and the hard drive was in use, it may have damaged it.
If it does not automatically connect to other PC's looks like it has been damaged
Aug 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Freecom external hard drive classic 2.5
Have a look here>
http://www.freecom.com/ecDrivers.asp
I can't see any Mac drivers for the drive...
I found this page>
http://freecom-usb-osx.sourceforge.net/
You might be able to get some help here...
Jan 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
Computers & Internet Logo
51 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
