Question about Water Heaters
Hot water heater restarts then turns off. This happens over and over again. It clicks off about 3 seconds after the burner actually fires up. Water Heater: Kenmore Power Miser 9 w/ White Rodgers Intelli vent controller
Service technician is probably best bet for troubleshooting all possible causes from plumbing leak to burner assembly needing cleaned to blower problem to bad gas control valve or tripped ECO, or combination of things listed above.
The intelli vent controller has error codes.
Open link for images, error codes and sample manual.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
I think the Kenmore is a Rheem product, but the market changes very fast.
Intellivent control indicates that water heater has a blower on top of heater that communicates with the gas control valve to coordinate combustion.
Rheem recommends the burner assembly be cleaned no less than once a year by trained service technician who has the tools and experience.
Newer gas water heaters, both tank and tankless are maintenance heavy because of energy and safety standards, and because of new electronic controls. Tankless require more frequent attention.
If problem is going to cost more than $330, then install new gas water heater yourself from local box store. I recommend avoiding electronics, and blowers, and tankless so you can hold down costs and maintain the unit yourself.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Water heater electronics and energy factor are good initial selling points, but all costs are energy, and repairs, service and parts of more sophisticated machines can cost more than the $1 to $8 saving you can expect under best circumstance.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 22, 2011
  • Anonymous May 22, 2011
    April 2011. This model Kenmore water heater is made by AO Smith.
I have a riello 40 burner it fires for 2 seconds then cuts out what could be the problem
If it actually fires up and you have a flame for 2 seconds and then it shuts off, I'd bet that the photo cell is either dirty or has failed. If it is dirty, it suggests that the burner has been neglected for some time and probably is in desperate need of a tune up. The photo cell is located under the ignition transformer and is aimed into the combustion chamber to see the light created by the flame from the burning oil.
If it is clean, the photocell has likely failed and will need to be replaced. If it still runs the same way after photocell replacement, it is probably related to the primary controller or one of the other safety devices. Is this a forced hot air or hot water system?
Oct 05, 2012 | Honeywell Biasi B10-3 Boiler ,riello...
Water not hot even thermostate turned to high. The pilot light is on. Shoulder I be able to visualise the burner actually firing.,or hear it firing. I can see the pilot light clearly. Please help
If you have cold water now, you should hear the unit fire up and run while heating water. Proceedure would be; pilot is lit with thermostat at pilot setting. Once pilot is lit, you turn up to desired temp setting and you should hear the heater running. Depending on lighting, you should be able to see it slightly brighter and may flicker some while heating.
Apr 25, 2011 | Rheem Water Heaters
Burners will not disengage after shutting off Hot Water.
Ok the way this system works is from a pressure and flow switch. The pressure switch picks up the slight drop in pressure when the hot side water is turned on then turns on the burner. The flow switch measures the amount of water flowing and adjusts the size of the burner to the amount of water flow. So a couple different things might be happening. The flow switch might be sticking causing the water heater to throttle down the burner but not off when the water flow is off. Or the gas control valve might be by-passing gas when off causing the burner to stay on even when the demand is off. Run the hot water on high demand then turn the water off. If the burner is still on try banging on the water heater with your hand and see if the burner shuts off completely. If it does the gas control valve might be by-passing. You would also need to check and see if the pressure/flow switch is giving any voltage signal changes when the water flow is off. These tankless water heaters are more comlplicated to work on than a standard water heater and you may need a professional's help...good luck
Sep 23, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Reheem powervent water heater blower runs, igniter on, gas valve opens, burner lights and runs for twenty seconds then turns off.
check the wires and make sure they are not touching any metal, or the gas valve, this is actually something I just had happen to a brand new power vent just last week the wires were touching the gas valve and shorint it out i seperated them put electric tape on each one it fired up and stayed on,,
Jun 27, 2009 | Water Heaters
Noritz not staying hot
How many faucets do you have on when this happens? Turn on more than 1 and if it still does the samt thing than I would check to see if the inlet water screen has debris in it. Valve off the unit and look at the inlet water side and theres a screeen that you should be able to remove and clean undeneith some running water and then replace. Good Luck
Jan 07, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Water Heaters Logo
698 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
