Question about GE Profile Harmony DPGT750EC Electric Dryer
Below is what an expert responded to me the other week. I have removed all the screws on the back panel of my harmony dryer but the panel wont budge. How do I remove it. Please help. Any more info would be great. I really appreciate it. I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the motor as that is bad and should be replaced....Hope this helps...please post back for further assistance.
  • 12 Answers
SOURCE: Whirlpool electric dryer
either you are pushing the dryer back to far and crushing the exhaust vent hose .your exhaust vent going outside is stopped up , or your low temp thermo will not let the dryer cycle and it is over heating.
Posted on Feb 28, 2008
aborcass
  • 2651 Answers
sounds like something getting to hot, perhaps clclyng thermo not regulating temp properly, although cleaned vent, when you pushed it back ito place did you crush or hkink line? peek over top and check
jumptrout51
  • 3361 Answers
SOURCE: Want to vent dryer from bottom. How do I remove the bottom/side
Unplug the dryer.
Open the dryer door.
Get on your knees and look up.
You will see 2 phillips head screws that must be removed from inside the door cavity.
Remove these screws, then the top of the dryer.
Then remove 2 screws on the right and left inside of the dryer.
Unhook the door wires and remove the front panel.
Posted on Feb 21, 2009
  • 207 Answers
SOURCE: How to get the front panel off GE Profile Harmony
Here's a simple overview of what you have to do:
You actually don't remove the back sir, but that's okay, that's a common misconception for this model dryer. The proper way to disassemble this particular dryer is you start with the top. You have to start with the removal of the control panel, then the top of the dryer. What I would consider the top cover. Then you'll have to remove two plastic brackets. Then you have to remove the front. There's two aluminum brackets in each corner, remove those. Open the door and there'll be two more screws to remove on each side. You have to lift the front just a little and then pull towards you. I forgot to mention, before that part, you'll need to ensure you are disconnecting the electrical wiring. There's almost no chance of connecting the wrong ones even if you forget. GE made this part novice proof. Once you get the front removed, you'll see the lint/trap. There's a couple of screws on either side of the aluminum housing. Not much to it. Let me know if there's anything I can clarify further. Have fun!
Posted on Apr 23, 2009
SOURCE: Clothes are not drying
your blower motor is probably not working. enter the troubleshooting mode by pressing and holding my cycles and help at the same time for 3 seconds. this will tell you the problem. if blower is not getting up to speed you'll have to replace it.
Posted on May 02, 2009
How to remove front panel on LG8001v dryer
Go to www.repairclinic.com and enter the model number of your dryer. You will be presented with a list of common replacement parts and may be able to view a video of the disassembly process. This may provide the information you need.
Feb 24, 2015 | Dryers
Remove back panel?
most you take apart from the front
Feb 07, 2015 | Dryers
How do you take off the back panel to get to the inside?
you cant remove the rear panel the sides and back are all one piece,you remove the control panel screws in the back,then the control panel,then the top panel cover comes off,the front then comes off,remove the drum belt and drum and you can get to the inside rear wall from here
Jul 17, 2011 | GE Profile Harmony DPGT750EC Electric...
Dryer turns on and acts normal, but does not get hot. Product is barely 1 year old.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 18, 2010 | Samsung DV219AE Dryer
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
I have a G.E profile dryer dpgt750 cant seem to figure out how to take off the back panel, the dryer is making a loud noise sounds like possible belt problem. any ideals? THANKS MARTY
Marty, you need to remove the front cover on these and most dryers by removing lower front kick panel screws, then remove the front cover and then you access the top cover screws to remove top cover then you can access th drum belt
Nov 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
How do you remove the back plate of a GE profile Harmony. I have the screws out, the top off. Does the back plate slide up? Do the sides have to come off with the back? Or what?Please. Thanks
the back plate does not come off.
to get to the motors, belt, sensors...
remove the screws to the inner top cover(under outer cover) and the plastic strips- slide strips front or back to remove.
remove the screws to the front panel- 2 top front, 4 inside door.
as you pull the front off, unhook the light and the door switch
remove the scres to the front drum plate.
reach under drum and unhook belt-take note how it goes around motor and tensioner.
lift drum out and observe everything else.
Jul 30, 2009 | GE Profile Harmony DPGT750EC Electric...
How do you disassemble a GE harmony dryer
remove rear pannel and the motor is right there remove drum to acess the motor
remember to lay the dryer on an angle or even flat on it's face if you can to re insert the drum assembly and dont forget the belt
Jul 29, 2009 | GE Profile Harmony DPGT750EC Electric...
How do you remove the outside panels to get at the belts for a maytag dryer that is model LDE7500ADW? We have taken the back and side screws out and the one piece panel won't budge.
Hi, There are 2 screws in the front panel down where the metal bevels in. Remove the screws and the front eill pull off.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Dryers
Ge profile dryer
look inside the dryer corners where the back panel is. there may be some bolts visible from INSIDE the dryer corners.
Dec 04, 2007 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
153 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
