Question about Mitsubishi WD-57732 Projection Television
Hi! We have a Mitsubishi TV WD-57732 and all the sudden, the composite and input 1/2/Front ports are not working anymore. Spent aan 1.5 hour on the phone with Mitsubishi tech sup trying a bunch of things which none worked. Because all ports seem to be unrecognizable by the TV, Tech Sup told me that I needed to re-initialized the software of the TV (now, this is different than the "MEnu" 1,2,3 steps). Anyone knows how to re-initialize the software? Or any other solution would be welcome as the kids are going crazy not having the Wii working... BTW, the Wii and DVD are working on other TVs in the house so I know that they are not the problem. The TV does not automatically recognized new devices connected... does not make any sense as everything was working find 2 weeks ago! Thanks for your help...
  • 2 more comments
  • Julie Roy May 21, 2011
    Jdvillanueva
    Thanks for the quick response.
    I did the steps you proposed, the input and composite ports are still not recognized. Any other suggestions?
    Regards, Julie
    Jdvillanueva
    It did reboot the TV but still do not see the Wii in the input port nor the DVD :-(
    Any other suggestions? Does it mean it is not a software but a hardware problem?
    Really appreciate your help.
    Julie
    Jdvillanueva
    Thank you so much. Wow! 12 hrs difference! It is amazing how the internet can make the world smaller. Mitsubishi already gave me the name of a recognized repair shop in my area, I will give them a call Monday.
    Thank you again, you were very helpful.
    Julie
    Thanks for all your help, Jdvillanueva. Although we were not able to solve the problem on-line, I now know what I have to do solve it. Jdvillanueva was quick and very knowledgeable and really appreciated his help.
  • Mitsubishi Master
  • 2,098 Answers
Hi Julie,
Restore the unit first to "factory settings" by following the steps below.
> Enter the service adjustment mode by pressing "Menu - 2 - 4 - 5 - 7"
> Press " 0 " when in the service mode. Three choices will appear at the top of the screen.
Scroll down to "Restores factory set values" by pressing the Up & down keys then press "Enter"
Try the unit. Let me know if the symptoms still persist.
Regards,
Jdvillanueva
Posted on May 21, 2011
  • 3 more comments
  • Jdvillanueva
    Jdvillanueva May 21, 2011
    Try again the steps below.
    Front Panel Initialization :
    While the unit is ON, pressing the FORMAT and INPUT buttons simultaneously will immediately start the Initialization sequence. The TV will reboot once the initialization sequence is completed.
  • Jdvillanueva
    NOTE: During Initialization, the set will reboot. Wait until the Power LED stops flashing before unplugging or powering ON the TV.
  • Jdvillanueva
    yes your right. you've anticipated what I will say. The caused of this problem is the faulty IC2k01 (AN15870A) also know as the video switch IC. I've already checked my link online for the parts availability but sad to say this is hard to find. I will advice you to contact Mitsubishi service center for parts availability.
  • Jdvillanueva
    But of course this kind of symptoms need to check by a qualified Mitsubishi Technician because bad solder joints and other parts in the circuitry must be check.
  • Jdvillanueva
    Its already 1:00 am here, I will take a sleep by now coz I will go to church at 5:00AM...
    Have a nice day!
My T.V. is making a weird clicking/popping/thumping sound and it sounds like it's coming from the speakers. It will do it for a few seconds stop and then do it again. It pauses the audio when it does...
Tries tv and cables or satalites services boxes unplug,replug it back like about an hour later for tv to do a whole tv set resetting itself back to factory setting and those services boxes rebooting and updating it software.Recheck all tv wires connections and sevices boxes for input cables wires for lose cables wire connections and damages connections cables wires.These steps should help,for stopping the volume just suddenly raise up and out of control for no apperance reasons.
May 28, 2011 | Mitsubishi WD-57732 Projection Television
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
My tv keeps shutting down when I turn on. The message on the the TV screen said that "the TV will be shutting down in a few minutes". I resit the lamp in the back of the TV and the TV works after I reset...
The first would be excessive dust causing inadequate airflow through the lamp cage. Cleaning the filter may resolve the problem.
It could also be that one, or both, of the temperature sensors could be defective. This is a known problem to the extent that Mitsubishi extended the warranty an extra two years on your model and similar models with the same design.
Mitsubishi Digital Electronics America, Inc (MDEA) 2006 DLP® Projection Televisions Models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD- 65732, WD-57831, WD-65831.
As part of our commitment to quality and customer satisfaction, MDEA is announcing an extension of the warranty coverage to replace the thermal sensor for the above referenced models. For a period of two additional years beyond the one year limited warranty, MDEA will cover the cost of the thermal sensor (parts and labor) at no charge. All other terms of the MDEA limited warranty will continue to apply.
Nov 30, 2017 | Mitsubishi WD-57732 Projection Television
My mits 62827 doesn't show the composite inputs, hdmi inputs, and the front tv input and they don't work when I plug stuff into them. I have tried to reset the tv, and tuned it off and unplugged it but it...
This set should have a soft reset and a hard one---try the soft reset first----with the set on and using the Mitsubishi remote MENU, 1, 2, 3, enter.
The set should turn off and come back on. Check to see if the missing things are back. Usually this happens if there was a momentary power outage etc.
You may have to auto program the set and on some models it removes labels(instead of DVD etc it will say video input) BE DONE OVER.
Let me know what happens and if you need help let me know.
If this helped you rate this solution as I do this here for free.
SD TECH .
Dec 14, 2009 | Mitsubishi WD-62827 62" Television
Wd 57732 won't turn on, power/timer light blinks
probably something related to the FMT board. will need shop service.
Aug 30, 2009 | Mitsubishi WD-57732 Projection Television
Error code 21
Try a hard reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Mar 11, 2017 | Mitsubishi WD-57732 Projection Television
Mitsubishi WD-57732 Projection Television Logo
176 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
