Question about Hitachi 51F59 51" HDTV Projection Television
Picture is turning red
After you turn it on the picture turns red what can be done to correct the problem?
  • pjragan Sep 02, 2008
    Too Much Red in Picture. 51F59 HDTV
I had the same problem, where the red CRT was shorted out. It kept on getting redder and redder until on day I turned in on and it was all red. CRT's can be pricey so it would be best to call a repair tech to diagnose the problem. Most will do in home service so you probably won't have to cart the tv somewhere. Once I replaced mine it's worked great ever since.
Posted on Aug 19, 2008
Red screen
Your red tube is going bad or the CRT board is cracked. Either way your TV is done. You cannot get replacement parts anymore.
Jun 06, 2012 | Philips 51PP9200D Television
Turn the tv on picture come on all red and fuzzy and then couple seconds later tv turns off and then turns back on with no picture just red screen then turns off and wont turn back on for ten min
It indicates a short at the Red picture tube--set has three picture tubes and each has a socket which processes signal to each tube--each has a single IC chip---in your case either the chip on the red board or the red tube.
If a bright red screen the set will detect something is pulling way too much current and shut the set down for protection---called a shutdown circuit.......
Apr 13, 2012 | Televison & Video
The screen turns red then the tv turns off
An issue dealing with the red picture tube but usually a simple adjustment of the screen control inside the set will correct this problem.
Apr 04, 2012 | Sony KP-65WS500 65" Rear Projection...
LNT5265F when first turned on new, small red light came on, played a little tune, then picture came on. About 7 months ago, after the tune played the picture didn't come on, the red light would go...
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board...
If the capacitors is faulty your TV turn on after a lot of attempt until the TV is totally turn on...
In that case you need to replace the bad capacitors on the power supply..
How can you find where is the faulty capacitors? The bad capacitors is usually leak/bulged on top in that case you easily find it through visual check...
Sep 10, 2011 | Samsung Televison & Video
Xbox 360
If you are getting nothing when you try to turn it on, no lights or anything...then check your power converter to see if it is supplying proper voltage. This can easily be done with a multimeter.
If the power converter is ok, I would call xbox and see about getting warranty work done.
If you are getting red lights where it shows what controllers are hooked up (they are green when working correctly), then you will most likely need warranty work.
If you xbox turns on but you are getting no picture to your tv, I would check it on a different TV to see if possibly the input ports on TV are fried.
Also check to make sure that all connections like power cord, RCA cables are hooked up correctly and firmly in their socket.
Hope this helps.
Sep 14, 2009 | Microsoft Video Game Consoles & Games
D80 Nikon - dark in viewfinder
What you see through the viewfinder is not exactly what you get in your picture. It is possible that your settings are just off in the camera. To make sure that this is the problem, set your settings to Auto and try again.
The red light before the picture is taken is a setting you can turn on to indicate that you have focused correctly. You can turn this off in the menu if this bothers you.
Lastly, I do not think your camera is broken. You just need to read your manual to make sure your settings are correct when you take a picture. Hope this helps.
NOTE: Please rate our help to keep this free service online
May 08, 2009 | Nikon D80 Digital Camera with 18-200mm...
Picture went green. how do i change bulb??
you can get the red replacement CRT at the following link and they provide free instructions. Heres the link to the correct red for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/red-crt/cName/phillipsmagnavox-tv-parts
Apr 20, 2009 | Philips 55PP9701 55" Rear Projection...
Turn on pic turns red with thin bright red horizontal lines
Sorry to say, but that's usually the sign of a bad picture tube. One of the elements inside the tube shorts and you see the picture you describe, and the set shuts down due to high voltages getting to places it shouldn't. There's no solution except picture tube replacement, and that is uneconomical. You're better off replacing the TV when the tube goes bad.
Mar 31, 2009 | Toshiba Televison & Video
Tv wont turn on after fixing convergence problem
Check the pins with a strong magnifying glass to make sure they are solderd correctly with none of the pins bridged with solder, then recheck all the wire connections to make certain they are correctly hooked up.
Apr 16, 2008 | Samsung HC-P4752W 47" Rear Projection...
Dark picture
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 13, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 51F59 51" HDTV Projection Television Logo
55 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
