Question about LG Washing Machines
Washer/Dryer WD14575RD. My machine displays AE. What does it mean?
2 Suggested Answers
SOURCE: my lg washer/steamer wd14756sd has
Code AE is a water leak. There is a float sensor in the base of the machine for this. The likely fault is the lower bellows drain hose as they are convoluted and this catches women's hair pins...the machine vibrations and water in turn rust these which pierce the hose. Hose bellows part number for LG WD14756SD is 4738ER1008A. Be careful for other machines the numbers/parts differ.
Unfortunately it's tight room to replace the hose but it can be done.
Posted on Jun 22, 2012
What dose it mean AE6 error code in Samsung wash machine
SAMSUNG WASHER FAULT CODES: AE or AE6
SAMSUNG WASHER ERROR DEFINITION = communication errors sub and main PBAs - main and inverter PBAs
AE and AE6 represent communication errors between the sub and main PBAs or the main and inverter PBAs.
HOW TO REPAIR/CLEAR ERROR?: If either of these errors is displayed, troubleshooting is needed or service is required.
http://removeandreplace.com/2016/06/15/samsung-washer-quick-troubleshooting-guide-error-code-definitions/
Feb 17, 2017 | Samsung Washing Machines
How do i fix error code AE on LG washer/dryer f1407adsp5
Hi.
Error AE is prompted when there is a leak detected at the base of the appliance or when the anti flood safety device gets activated.
Disconnect power by unplugging power cord or resetting circuit breaker.
While power is off remove any water present at the base of the appliance.
If there is no water, check the pressure switch, wiring and control board for faults that may result in error AE. Check also setting of the drain hose at the back (it may cause siphoning), and make sure that inlet valve is not leaking.
Regards.
Ginko
Aug 28, 2011 | LG WM-2277HW Front Load Washer
My lg washer/steamer wd14756sd has the ae code on display. what does this mean?
Jan 16, 2011 | LG Washing Machines
Washer dryer 8 - 4kg code WD-1457-RD It has come up with AE half way through a wash -- how do i fix it?? Thanks Kate
Did u figure out an answer to this Kate? this as just happened to ours and can't work out what it means! Aaron
Dec 22, 2010 | LG WD-12124RD Front Load Washer
Ae display warning
Hi
Error AE means that the machine has detected a leak in the base of the washer. The anti flood device has detected the water and its displaying the error AE.
Unplug the washer and remove the back panel of the washer. Check for any stagnant water present in the base of the washer. If no water is present then check for the anti flood sensor and any disconnected wires.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | LG WM-12120BD Front Load All-in-One Washer...
My machine is a WD640 washer/dryer and is displaying in the led display F-01 ? The machine will also not fill with water but the countdown on the cycles are working
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F01 on a Washer Dryer means you have a motor fault. Check the motor and associated wiring. You may just have a broken wire. Click on the link for more Hotpoint, Creda and Indesit error codes. Or use these links for WMA & WM workshop manuals.
Mar 11, 2010 | Hotpoint Aquarius WD640 Front Load...
DRYER NOT WORKING
E10 means theres no water going into the machine.Your machine has a triple water valve the 1 that feeds the dryer has proberly failed. Comes as a comp unit.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
New LG Washer Dryer
Are you sure it's says AE for the error code.  LG doesn't list that particular error code.  Please check again.
Apr 19, 2008 | LG WM-2277HW Front Load Washer
Bosch washer/dryer
I also have the same washer and same problem, and it is not due to clogged filters nor due to low pressure!
Any solutions so far?
I wish I had read these posts before buying it. :(
Mar 27, 2008 | Washing Machines
Washing Machines Logo
87 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
