How do i reset my date and time on the computer?
  • 92 Answers
Double click to the lower right corner of your screen, it indicates there the time and date you can now change the time and date setting of your computer..
Posted on May 21, 2011
To reset the clock on my computer
hi robert.
try this.
To set the date and time on your computer:
  1. Press the Windows key on your keyboard to display the taskbar if it isn't visible. ...
  2. Right-click the Date/Time display on the taskbar and then choose Adjust Date/Time from the shortcut menu. ...
  3. Click the Change Date and Time button. ...
  4. Enter a new time in the Time field.
More items...
For Seniors: How to Set the Date and Time on Your Computer - dummies
www.dummies.com/.../for-seniors-how-to-set-the-date-and-time-on-your-computer/
or go to this link might help you.
how to reset the clock on my computer Google Search
Nov 02, 2017 | The Computers & Internet
After programming the time, when i input a transaction, the wrong time appears on the receipt and now has reset itself to 00.00 and 00.00.0001 for date. Why is this?
I don't know how a Sharp Cash Register works but computers reset to default orignal date (i.e. mine is 01-01-2008) when the battery of CMOS is discharged. You can setup current date but when you turn off the computer, it resets to this original date. Might be the same problem with your Cash Register?
Oct 08, 2015 | Sharp XE-A102 Cash Register
How to change time and date on my pc
are running a Windows computer you should place the mouse pointer over the date/time, usually at the bottom right corner of your screen. Right mouse click on the date/time and scroll down to "adjust date/time" and left mouse click on that. A window will appear allowing you to reset the date/time. You can also change the time zone to your particular time zone. Some O/S will allow you to select internet time, which automatically keeps the correct time.
Jul 15, 2014 | Gateway Computers & Internet
The time/clock on my computer is 2 hr.s slow.
click start control panel date and time you can make your adjustments to the date and time from there or right click on the date and time and you should see Adjust date and time tab hope this helps
May 27, 2011 | Computers & Internet
Everytime I turn on my computer, I have to do F1 and reset the time and date. How do I replace the battery? It has gotten so bad, sometimes I have to press and hold start button, turns off and restart it
Hi philco1977,
Good day. The BIOS prompts you to press F1 key and reset the time and date in your system. This is caused by a CMOS battery that needs to be replaced in your motherboard which is unable to save the time and settings in your computer. In order to replace the CMOS battery, you must open your computer and in the motherboard you may see a coin cell battery. You can take it out using you hand or you may use a flat screw driver or a knife. Make it sure that when you do the replacement the computer must be turned off. Once you are done with the replacement you may have to go again to the BIOS and reset the settings again including the time and date and it will never prompt you anymore to reset you time and date settings.
Thanks,
allanhunt
Apr 22, 2011 | Computers & Internet
Date &time change every time I turn on my pc.why? how to fix the problem?
Hi elfridapanot,
The CMOS battery in the motherboard is be weak. Thats why the time resets every time you start you computer. Open up the computer case, and look for a battery on the motherboard. Take it out carefully and replace it with a new battery. Then start your computer and set the date. Next time when you restart, the date will not be reset.
If this information was helpful, please rate it.
Thank you for using Fixya,
Arun Zac
Dec 07, 2010 | Computers & Internet
How do i reset the date and time without replacing rtc
You can do it from within the BIOS settings if you want. Choose F2 at startup and that will take you into startup. There you can change the date and time. If you are in Windows and want to change the time and date, simply left click on the time indicator on the taskbar and when the window pops up, choose change date and time. Make sure of the corrected date is in fact correct or your computer will not function correctly.
May 21, 2010 | HP Compaq nc6000 Notebook
My date has to be reset every time I turn on my computer. How do I ensure the date and time is memorised thereby avoiding resetting. Thank you.
most of the cases the main reason behind the date time reset problem occurs due to weak CMOS battery on the motherboard. So, you just need to change your CMOS battery on your motherboard to resolve this problem.
Mar 29, 2010 | Computers & Internet
Set Date
Entering the Date and Time Note: When your machine is connected to a computer with the MP driver installed, even if the date and time are entered from the Operation Panel of the machine, the date and time will be read from your computer every time you start the computer, turn the machine on, or disconnect and connect the USB cable. When using your machine connecting to your computer, set the date and time on your computer precisely.
The date and time will be reset when you disconnect the power cord or there is a power failure. In this case, you can set it again on the machine. Alternatively, it can be read from your computer and set on the machine by connecting the machine to your computer with the MP driver installed.
1. Press [FAX], then press [Menu].
2. Use [ left ] or [ right ] to select <USER SETTINGS>.
3. Press [OK] two times.
4. Use the numeric buttons to enter the date and time (in 24-hour format). Enter only the last two digits of the year.
5. Press [OK].
6. Press [Stop/Reset].
Sep 13, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Time and date change
Go to your Bios Settings. Change the System Date there.
Dec 27, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
