Question about Goldstar Dehumidifiers
Deuhumidifier will turn on, but not for long and no water is dispensed. Filter is clean. is the compressor gone?
  • Goldstar Master
  • 43,501 Answers
Hi, Yup, compressor may be shot, but it may also be the PCB...at any rate it is not worth trying to fix...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on May 27, 2011
Error code 67
Error code 67 is an airflow problem. Either clogged filter or bad blower motor. Unplug unit remove bucket and feel for filter in front behind cover it drops down. Clean filter with water and reinsert. Plug unit in turn to "on", fan should begin to run, after 3-5 minutes compressor should start. If fan does not start it is bad and should be replaced.
Jul 07, 2012 | LG LHD65EBL Dehumidifier
Kenmore dehumidifier compressor on but doesn't collect water
clean the condenser in the front or the filter if it has one. no air flow to cool it down will result in overheating and no condensation collection across the evaporator coil.
May 09, 2012 | Kenmore Dehumidifiers
How do you check compressor on LG LHD45EL
If you just want to make sure the compressor is running, turn it to the lowest humidity extraction level setting, which is 35%. If the air intake filter is clean, and the water bucket is empty, the compressor should turn ON, in less than a minute.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | LG LHD45EL Dehumidifier
Dehumidifier runs continuously but but no water comes out. I cleaned the filter and behind the filter. Plenty of space on sides and back. Was running fine right before it stopped dispensing water. ...
Bill, There are 5 basic, but solvable reason for what you described. You have already eliminated 2 of them. But the rest still apply. Especially # 1.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications . Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helped you further troubleshoot and solve the problem. Please let me know. Thanks.
Jul 08, 2011 | Goldstar Dehumidifiers
My DeLonghi dehumidifier will not collect water. I have cleaned the filter and have made sure there is plenty of space for ventillation.
heatman101
Jun 08, 2011 | DeLonghi Dehumidifiers
The compressor does not kick on - this is the second one I have purchased in the last couple of years and believe there must be some things I can check out on my own. I only run it during the summer...
Yes, there are some things you can check.
The first thing to check is the setting on the Dehumidifier. If it's above 60%, it's not likely that the compressor will turn ON, as 60% is a pretty high humidity level. Keep in mind, if it's set at 60% that's what it will maintain, not remove. Lowering the level to 45% will have a much bigger effect.
Now, let's suppose, after turning the setting down, it doesn't cause the compressor to turn ON.
Take the unit into the bathroom, plug it in and turn it ON, with the Humidity setting at 45% or lower. Turn the shower on, using hot water and on the way out close the door. DO NOT run the exhaust fan in the bathroom. Wait about 15 to 20 minutes, return to the bathroom, turn the shower OFF and check the water collection bucket for water. If any water is in the bucket, your unit is working as it should.
Routine Maintenance:
Check and clean the air intake filter regularly. A clogged filter causes the compressor strain to keep up. Also, cleaning the coolant coils prior to using it in the Summer, can go a long way. After cleaning, a light coat of WD40 really helps.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 17, 2011 | LG LHD45EL Dehumidifier
Dehumdifier not collecting water.
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Turns on but blows out warm air
Is the compressor on as well? or just the fan, if the compressor is on and fan is on and it is blowing warm air it could be a charge (refrigerant problem)
Jul 27, 2009 | Goldstar DH4010B Dehumidifier
No water is collecting on 2 year old lg humidifier
If when you turn your dehumidifier on the compressor runs then you should get moisture. Dehumidifiers work on the same principal as refrigeration. There is a bad control switch or the compressor start relay or capacitor is defective. If compressor runs and there is no effect then that is another problem. The filter should come out the front where the air goes in front and the filter should be washed by hand in warm degrease detergent water, dry and replace. If the disposable type filter I will help you contact LG.Thanks, Sea Breeze
Jun 17, 2009 | LG LHD45EL Dehumidifier
Kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Jul 31, 2008 | Dehumidifiers
Dehumidifiers Logo
66 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
