Question about Samsung Galaxy S GTI9000 Smartphone
When I connected the phone via USB to my PC this appears : There was a problem installing this hardware MTP device An error occurrd during the installation of the device. The required sction was not found in the INF
  • mbnario72 May 22, 2011
    I tried that already it didn't work twice tnx
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 78 Answers
Reinstall the Kies software or upgrade it , seems like a driver problem If you like the solution kindly give us all thumbs up
Farhan
Posted on May 21, 2011
    Tried that already twice it didn't work tnx
Nwz-e344 sony walkman isn't being recognized by my computer
If your PC has windows XP sp2 or later and Windows Media Player 11 try to do these steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
I hope this helps.
Thanks.
gylacz
Sep 01, 2011 | Sony Walkman Video NWZS615F MP3 Player
Tip
My Computer won't recognize my MP3 player...
For Windows XP users: verify the following operating system requirements are met.- Windows XP SP2 or higher- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.- Download the hotfix from http://support.microsoft.com/kb/939211.- Run the hotfix.
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
Next:-- Refresh the drivers. Connect the MP3 player to the PC. The screen on your player should turn on, show 'Connected' and indicate the battery is charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.NOTE: - If there is nothing showing on the screen and the player does show up as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed.
Next - Check under Device Manager1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane.
NOTE: Most MP3 Players can connect to your computer in MSC or MTP mode. There are exceptions which only use MTP mode. MTP mode is the recommended and default method for some MP3 players. Some players will show up on Device Manager's right pane as:1. USB Mass Storage device (if the player is set to MSC)2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, refresh the drivers. To refresh the drivers1. Right-click the error mark, select Uninstall.2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed.
Next: - Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player.
The USB Mode setting can be enabled on some players after updating to the latest firmware. If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the firmware.
on May 31, 2010 | Audio Players & Recorders
I can't my samsung yp-u2j in my pc an i already
You need to upgrade your player’s firmware if you experience any of the following:
  • When your attempt to use the player, the Found New Hardware bubble appears and then flashes between several messages including MTP Connected, Don't Disconnect, MTP Device found, MTP Device may not work properly, or There was a problem during installation.
  • The player constantly appears and disappears in Device Manager or appears in Device Manager with an exclamation point indicating an error.
  • Your computer sounds the connecting and disconnecting chime when you connect the player to the USB port.
  • The player does not appear in My Computer.
  • Uninstalling Windows Media Player 11 and using Windows Media Player 10 corrects the issue.
  • When you use the player on another PC or laptop, it works flawlessly.
  • Your player was working properly with Windows Media Player 10, but you’ve recently upgraded to Windows Media Player 11 and your computer no longer detects it.
  • Go to Samsung.com, enter in the model u have in the search area and then go to support, this should fix the problem!
May 28, 2010 | Samsung YP-U2JZW MP3 Player
I am unable to connect my Samsung SGH 600 to my PC
sounds like you need to uninstall the software, reinstall it and then connect your phone.  If you are usng the front USB panels, try the back ones.  Sometime the front connectors are USB1 and are not fast enough.
Mar 06, 2009 | Samsung SGH-G600 Cellular Phone
USB connection problem
I think I got it guys. forget WMP 9,. 10 , 11... I run win xp service pack 2 and could not install the samsung yp-u3 player. I kept having it found as a new hardware {portable device} but as we all know this software has no drivers, and the windows update produces MTP device error. Resulting in you not being able to see your player in XP. Well go to windows update site and search for a file called "mtppk12.exe" I'm pretty sure once you install that file and reboot, you will no longer have MTP device errors. However, I installed this at the same time i installed windows media player SDK. So maybe both files are required. Finally after 2 days of troubleshooting i got mine to work.
Jul 29, 2008 | Samsung YP-U3 MP3 Player
MTP DEVICE Sony 4gb walkman NWZ-S616 not installing
if you have a problem about MTP Device and wont be able to show in your "My Computer", here are tips that may help you fixed your problem:
*First- Uninstall the MTP Device Driver in your system.(Right click My Computer then manage, then click Device manager at the left part, then after that, find MTP Device in your right part, then click and Right click the name of your MTP Device then uninstall.)
*Second- Reconnect the device and then after a pop-up show which says, New hardware found,
click install the driver in a specific location, then choose the bottom option and then choose
Storage Device.
*Lastly- Turn On your Device and search it in My Computer.
that's all, and i hope i do a little help to you!
Mark Anthony Quintana
Dec 09, 2007 | Audio Players & Recorders
Sansa View not appearing in My Computer
In that case, I'd suggest you to check whether do you have latest version of USB 2.0 installed in your computer or not. Also you can try by connecting the device in different USB port.If still the same, please go ahead and update the latest MTP drivers.
Steps needs to be followed up to update MTP drivers :
1. With the Sansa connected to your computer, open the Safely Remove Hardware icon in the system tray.
2. Select the USB Mass Storage Device.
3. Click the Properties button.
4. Go to the Drivers tab.
5. Click the Update Driver button.
6. Select Yes at this time only, then click Next.
7. Select Install the Software Automatically, then click Next.
8. This should update the MTP Device driver. You may be prompted to restart the computer.
Nov 30, 2007 | Computers & Internet
YP-U2J MP3 PLAYER
hmm i got the same problem as jenn1519 ill plug mine in and when i usually plug it in the computer makes a bing noise like it recognizes that its in the usb plug but 2 seconds later it will make the bong noise that i unplugged it which i didnt so i cant put any new music on. it will charge but it wont let me get any music on. and windows doesnt read that its in there.
and also my mp3 player is very important for me its a gift from a friend so plzz plzz help ? :(
tanko!!!
its ma emil add hot_chilligirl@yahoo.com.au
Sep 11, 2007 | Samsung YP-U2X Digital Media Player
Samsung Galaxy S GTI9000 Smartphone Logo
447 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
