Question about Thermador SEC272BS Stainless Steel Electric Double Oven
Our Thermador double oven SEC272BS shuts off repeatadly during heat-up. What causes this?
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
  • 5 Answers
SOURCE: thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Posted on Jan 15, 2009
kachbibi1
  • 979 Answers
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Posted on Jan 30, 2009
Macmarkus
  • 2605 Answers
SOURCE: The clock works but the oven does not heat up
Hello George, welcome to fixya.
The symptoms you describe are a common occurrence when the hi-limit has tripped. This typically occur's following a self clean cycle. The display will indicate the oven is indeed "on" but it will not heat do to the circuit being interrupted by the hi-limit ( which is what it was designed to do ).
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly. **Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...if indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...52bc5ab.jpg
Let me know if I can assist you further. If this solves your problem please rate the solution accordingly, if not let me know and I`ll try to guide you through other possible scenario`s.
Thanks for visiting "fixya" and good luck.
macmarkus :)
Posted on Jun 15, 2010
SOURCE: Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Posted on Jan 31, 2011
Oven will not heat up broiler works. its a thermador rdss oven
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 ';
Mar 07, 2011 | Thermador SMW272 Electric Double Oven
What is error code F34 on the thermadore built in double oven
If your Thermador was manufactured between 2004 and 2007, this may be due to a recall issue. I kept getting this error on my Thermador wall oven when I would run the self-cleaning feature, and when heating it over 375 degrees. After doing some research, I discovered that my oven was recalled. Apparently there are gaps in the insulation which could cause a fire. You can find out more on the Thermador website: http://www.thermador.com/safety-notices/7_oven-safety-recall-notice-expanded
Oct 15, 2010 | Ovens
My thermador double oven does not turn off for 30 minutes.
Welcome to FixYa.
Please clarify if I`ve misunderstood what you`re asking, but with all Thermador ranges and wall ovens ( including your SC302T model, most brands in fact ) the cooling fans will remain on for quite some time after actually shutting the oven off.
This is done by design to keep the electronics cooled to a temperature usually below 200°F so they aren`t damaged.
Heat after all is the thing which damages electronics more than anything else.
I do have use and care guides available via email attachments in "pdf" if you need one.
Thank you for choosing FixYa. I hope this eases your concern. Please let me know.
Regards,
Macmarkus :)
Sep 07, 2010 | Thermador SC302T Electric Double Oven
Thermador smw272 oven does not heat. the op panel
Likely to be the Hi Limit Switch or the relay/power board.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | Thermador C302U Electric Double Oven
Oven takes forever to heat up - its a thermador double oven - me272
Hello- Check these things first-  Door seals tend to get stiff over time. This is normal. Door hinges can become loose or get bent a bit, causing door to not close tight. This little gap can allow heat to escape, causing extended pre-heat times and frequent cycling of elements. If door doesn't seem to pull shut tightly- hinges will need to be replaced. If oven appears to operate normally otherwise, this should solve problem.  Let me know if the info helps- have more if needed- Thanks  - Ed
Mar 17, 2010 | Thermador C272 Electric Double Oven
I have a Thermador double convection oven, that I'm getting a f54 code plus a lockout indicator readout at times. Whats that all about.
because you used self cleaner funtions that burn will cause machine over heat try to remove the oven and check the thermo limit in the back of the oven
Jan 12, 2010 | Thermador SMW272 Electric Double Oven
F24 Error code and incessant beeping
Being a software developer I guessed that the keyboard (the touch pad) was bad, because in my case one of the keys (the Top Oven OFF key) did not beep or work. So I went on the Thermador website and found the touchpad on the schematic. I ordered one yesterday from a firm called Mar-Cone in St. Louis, and it arrived today. It is a very easy replacement, and takes about 10 minutes. Happily it was a good guess, and it works fine. For the 27" SEC272BS/01 (stainless) the part # is 474083, and cost $189.20. They will express ship for $25.
Phew, we have 20 people coming for dinner on Thursday.
I'll be happy to let anyone know how to change the panel.
Nov 09, 2008 | Thermador SC272T Electric Double Oven
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Oven turns off
call Thermador service center 800 735 4328
they said that if you have had an electrical outage or surge recently-
turn off dedicated circuit at circuit breaker for 1 HOUR
Feb 27, 2008 | Thermador C301U Electric Single Oven
Thermador SEC272BS Stainless Steel Electric Double Oven Logo
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
