Question about Kenmore 63252 Microwave Oven
Microwave turntable not turning, not heating up I have a fuse to try to replace, but don't know where it's located. Model # is 565. 69421
  • Kenmore Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,./';';
Posted on Aug 13, 2011
I have to replace microwave light bulb. It's GE counter top Microwave JES1142PSE model. I hace opened the microwave and have located the bulb,but could not unscrew.I don't know needs to be pul
That exact model number is not showing up, so you may want to check the tag on or in the unit and look here for parts.
Most of the models in this class of ovens were not really made to be serviced, so GE only makes the turntable parts available.
It also sounds like your bulb is an assembly - the socket and bulb and one piece.
So your local appliance parts store should have a generic replacement for it. You should take the bulb.
Be careful when disconnecting the leads.
Apr 14, 2013 | GE Microwave Ovens
Phillips microwave oven vt255/bl tuntable does not rotate
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to one of these problems explain below
(1)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properl on the turning mechanism.
(2)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(3)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
FOLLOW THESE STEPS TO REPLACE THE FAULTY MOTOR.
THINGS NEEDED.
* screwdrivers
* replacement motor
* specific microwave information and part number
1 Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3 Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4 Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5 Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6 Reinsthall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Whirlpool Microwave Ovens
Phillips whirlpool microwave turntable not turning
HELLO.
Your microwave turntable may not turn due to any of these problems explained below.
(a)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properly on the turning mechanism.
(b)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
(c)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
follow these steps below to replace the faulty motor.
1. Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 .Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3. Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4. Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5. Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6. Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Microwave Ovens
The turntable on my GE Spacemaker Microwave JVM1640BB does not turn.... I can turn it by hand, but does not turn during cooking.
HELLO.
THINGS NEEDED.
* screwdrivers
* replacement motor
6 Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Hoping to help on more problems.
THANKS.
Sep 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Russell Hobbs Microwave ,it heats the food but it does not turn round.
If the oven is STILL heating, but the carousel isn't turning, the symptoms you describe are commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
The average price for a motor is usually about $25 to $45 (U.S. Dollars). If your model number is not listed at all the sites, you may also try these sites that carry the Russell Hobbs brand parts:
http://www.russell-hobbs.com/parts.shtml http://www.directpartsandproducts.com/index.php NOTE: Even though the carousel may not be turning, you can still use the microwave while awaiting parts. You will need to physically rotate whatever you are heating about midway through the cook time to ensure even heating. Early model microwave ovens were not equipped with a rotating carousel and this was the common procedure.
May 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker JVM1730 the turntable stopped turning. The next day it started to turn, but stopped. I tried cleaning the parts,but no help
repairclinic.com
The average price for a motor is about $25 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is either WB26X10233 or WB26X10038 (depends upon your COMPLETE model number). If your model number does not cross reference to all websites, use the part number from the Sears website as your search criteria.
May 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable stopped turning one day last week. Will turn slowly without glass plate on spindle, but not with any weight. Is there a schematic for turntable drive somewhere?
If the oven is STILL heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
repairclinic.com
The average price for a motor is about $25 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is WB26X10038 (listed as item 43). If your model number does not cross reference to all websites, use the part number from the Sears website as your search criteria.
May 09, 2011 | Hotpoint RVM1425 Microwave Oven
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
Sharp Carousel Microwave Convection R-820JS. Oven gets hot but turntable does not rotate causing uneven baking.
repairclinic.com
The average price for a motor is about $35 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is RMOTDA254WRZZ (listed as item 1-3 under the "Oven and Cabinet" parts section. If your model number does not cross reference to all websites, use the part number from the Sears website as your search criteria.
Apr 28, 2011 | Microwave Ovens
Model # UMV1152BAQ,S/N 10406839EN Linkage to
repairclinic.com
The average price for a motor is about $35 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is W10207571 (listed as item 22 in the parts drawing under the "Internal Controls" parts section.
Apr 20, 2011 | Maytag Appliances Over-the-Range Microwave...
Kenmore 63252 Microwave Oven Logo
162 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
