Question about Makita 9404 4'' x 24'' Belt Sander
The graphite and rubber pad on my makita belt sander 9404 have come off. Can they replaced with new?
  • 969 Answers
SOURCE: I need a new rubber pad.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/BO5001
They have all parts.
Posted on Nov 05, 2009
rowdy45176
  • 2176 Answers
SOURCE: The belts on my Makita 9304 belt sander are wearing unevenly
check the wear plate on the bottom and also check the front roller for being out of round is where I would start. Let me know if doesnt help
Posted on Feb 18, 2009
SOURCE: looking for a manuel for a makita belt sander model #9401
I have just purchased a Makita 9401 belt sander however, have no manual and it is unclear how to change the belt. Any help would be appreciated.
Thanks
Joe
Posted on Mar 15, 2009
rowdy45176
  • 2176 Answers
SOURCE: Brushes on my sander are wearing out within 10mins
the armature could be the problem, when you replace them do you notice a lot of arcing around the commutator, it might be bad or just need to have the surface cleaned. let me know.
Posted on Jan 22, 2010
SOURCE: new rubber drive for makita 100 mm belt sander
WENT TO RUBBERMAN IN GEORGE AND FOR R20.00 THEY REPLACED THE RUBBER ON THE DRIVE WHEEL-BEATS PAQYING THE THOUSANDS FOR IMPORTED SPARES.G
Posted on Sep 30, 2010
How to install drive roller on my makita 9401 belt sander
DONT forget to order and replace also allways the sinter bearingbus on the machine because to protect you from a dissapointment because otherwise the belt will turns off and cant be (good) controlled again , replace the drive roller allways and clean the front roller axle if its only dirt on the front roller use a little sillicon grease film on the front behind can use a little bit more sillicon grease between the axle rings and new bearing bus. remove the dry grease in the driving gear space and renew the lubricant in it with a multipurpose grease .
Sep 04, 2014 | Makita 9404 4'' x 24'' Belt Sander
How to clean a clogged belt sander
I assume you mean you want to clean the belt itself? You can use a rubber stick made for this. It looks and smells like a giant pencil eraser, about 1 inch square and about 10 inches long. However, if the belt is clogged with melted paint, that won't do much - but a stiff wire brush works OK. If the wire brush doesn't work, get a new belt. You can avoid the melted paint buildup (or at least reduce it) if you keep the sander moving rapidly over the surface, and use a good quality scraper to remove as much paint as possible before sanding.
Sep 19, 2012 | Makita 9404 4'' x 24'' Belt Sander
Ihave replaced the brushes on my 9404 belt sander and it is running as if it still needs the brushes changing. Any ideaS?
If there is excess sparking from the brushes then the armature is shorted. Also a bad field can make a tool run slow.
Aug 07, 2012 | Makita 9404 4'' x 24'' Belt Sander
Makita Belt Sander 9404 - dust collection bag not collecting the dust. Shooting dust out the front. What can be done to remedy this?
the tool needs cleaned thoroughly. there might be a section of a belt that has jammed the passageway. UNPLUG the tool and turn over to see on the backside if the clog is there, if not I would recommend using safety glasses and compressed air to blow thru the channels to dislodge the material. I havae also used a shop vac to help in this.
Jul 27, 2011 | Makita 9404 4'' x 24'' Belt Sander
The electric cable has got caught in the sander. How do I unassemble to remove the cable?
Hi Mark,
Hear is an exploded parts diagram for the sander:
http://www.powertoolspares.com/tool/makita/spares-and-accessories-for-9404/9404/spares/
Remove the three screws on the handle cover part 23 to expose the cable connection to the trigger switch.
Apr 28, 2011 | Makita 9404 4'' x 24'' Belt Sander
My makita 4"X24" sander makes
http://www.ereplacementparts.com/makita-9404-belt-sander-parts-c-97_103_535.html
I would say you have a bearing going out ether on the motor this web address will take you to a good break down of the housing I would say you need a motor bearing it will also give you a parts # but if you have a bearing supplier somewhere ( I look in yellow pages for electrical motor repair) you might find the bearing for a cheaper price just remember to take the old one with you so you are sure to get the same size. I have found bearing and belts for my table saws are the same as for some clothes washers for about 1/2 the price as ordering from sears
good luck
Pat
Oct 29, 2010 | Makita 9404 4'' x 24'' Belt Sander
Jan 22, 2010 | Makita 9404 4'' x 24'' Belt Sander
New rubber drive for makita 100 mm belt sander were can i get one
Dec 27, 2009 | Makita 9404 4'' x 24'' Belt Sander
HOW TO CHANGE THE BELT ON A BELT SANDER
There is a lever on the side of the unit, flip the lever and then slid the belt off.
Jun 13, 2009 | Makita 9404 4'' x 24'' Belt Sander
Feb 17, 2009 | Makita 9404 4'' x 24'' Belt Sander
Makita 9404 4'' x 24'' Belt Sander Logo
236 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
