I need a circuit diagram for the PSR-2000 to check which component on the circuitboard needs to be replaced or changed .
zapco
  • 30 Answers
SOURCE: ALPINE MRV F400 AMPLIFIER
your best would be to contact alpine for that info on there website...that is a old amp .
Posted on Jun 23, 2008
SOURCE: Need schematic diagram, some advice and ultimately replacement parts
You have something in short circuit in power supply pattern, so filter coils are burnt. It may be voltage regulator, or regulating transistor, electrolytic capacitor or even shorted diode at pwr. input serving to protect in case of inverse polarity applied. Check all for short. Was it reverse polarity or overvoltage occured?
Mladen,
mladen@propilots.net
Posted on Mar 14, 2009
  • 293 Answers
SOURCE: HAVE VIDEO BUT NOT BACK LIGTH
Believe it or not most of the components of the Acer laptop screens are the same. However that is a problem because 90% of the screens are integrated circuitry not easily replaced. Most of those parts aren't sold seperately. My suggestion if you want to keep the laptop is remove the old screen in whole and replace it. It will be cheaper in the long run and easier.
Posted on Apr 21, 2009
SOURCE: I GOT A SHORT CIRCUIT AND LOST THE BACK LIGTH OF
u can concert with me on my mail id amit_arya8382@yahoo.com with ur model number of laptop than i can trobleshoot the problem thjanx enjoy good luck plz vote on my comments
Posted on Sep 03, 2009
hattonhall
  • 349 Answers
SOURCE: I need the circuit board diagram for the control
It is always better to do a factory exchange for a complete panel as you never know whats gonna fail next after a DIY panel repair.
Posted on Oct 19, 2009
I have a Yamaha PSR 2000 keyboard. You can not see the keyboard. It lights up but you can not read anyting on it. It is blank. Can it be replaced what part would one need to fix the problem? I had scr
If you have a light behind the screen then the backlight is working. It could be a connection from the board to screen but this is very unusual.
These screens have been know to fail and will need replacing.
HOWEVER
The screen is not a simple and requires an extra driver board and various components to be replaced/changed. You will need soldering equipment for surface mounted resistors etc if wish to undertake this.
The replacement kits including the screen cost around £ 400.00
Have you tried a factory reset?
Hold down top / highest white key whilst turning the keyboard on.
Good luck
Jan 05, 2015 | Yamaha Music
Check engine light produces a p1155 and 1135. both say same thing open ground, heater control circuit failure PCM failed but for bank 1 and bank 2. not passing emissions.
Do you have a wiring diagram(s)? Find one,if not.
All data is helpful,but they charge $26.95 for a year.
Free is better.
Check for recalls on your model. NHTSA.
Check PCV and EGR valves for leaks,vacuum booster and...More.
Circuit voltage on harness side,not with an ohm meter at component.
You may need a more expensive diagnostic tool.
Get into an Avalon forum to see if that code has been difficult to diagnose.
Nov 11, 2014 | 2000 Toyota Avalon
Power window
Now you need a factory wiring diagram & do some testing
eg: voltage drop your way from the battery or back from the motor,
until you find the open in the circuit or failed component
You say you HAD the switch checked
Are those same people not capable of finding the issue?
Mar 27, 2014 | Chevrolet Tahoe Cars & Trucks
Kenmore elite dishwasher
If you had a fault in your neutral wire the voltage may have raised to near 220 volts and fried the circuitboard. Replave the circuitboard or replace the thermistor on it. Double check the voltage and the connections where it is wired under the dishwasher.
Nov 19, 2013 | Dishwashers
Finding yamaha psr 450 circuit board with part #28750 DM X7588
The actual part # is WC35550R but is costly! $400.00 from Yamaha.
Nov 14, 2012 | Music
Repairing Yamaha psr-12
If the power adapter is not the original adappter- check to make sure the polarity is correct- it should be marked on the keyboard near the adapter socket, and also on the adapter itself.
The keyboard should have an internal fuse- check that. Then with keyboard open, if the fuse is okay, trace the power flow from the power pack and look for broken wires, bad solder connections, stressed components like bulging capacitors, etc. It may have a burned out zener diode in the power supply regulator portion of the main circuit.
Mar 29, 2012 | Yamaha PSR-E223 keyboard
Yamaha psr-280 flashing display no key response or sound. Is it dead??
Your adapter should be a 12 volt DC delivering 2 amps (2000 ma). If the adapter is too small, you will have the symptoms you are seeing. Make sure the polarity is correct. DO NOT use the so called "universal adapters".
Apr 13, 2011 | HQRP AC Adapter / Power Supply for Yamaha...
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
PSR-2100 need to find replacement circuit board.
I don't have a parts source for these other than Yamaha. Call them up to get the part number for the board. The sound is usually sent through the headphone jack which acts as a switch when you use headphones. Replacing that board should resolve your problem. If the board is no longer available, it is possible to repair the existing one, but this is a specialty task and not one I would recommend a novice attempt.
Please keep us posted on your progress,
Dan
Jul 24, 2009 | Yamaha Music
GE 30" Self-Cleaning oven
I do not think that the problem is caused by the broil element, but I cannot rule that out. I believe there is a short or an open in the circuitboard. Unless you find the short or open you will need to replace the entire control board.
Jul 30, 2008 | GE 30" Self-Cleaning Freestanding Electric...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
