Question about Packard Bell Speaker Computer Speakers
Plug in speakers work fine. Internal ones do not work
  • Packard Bell Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 21, 2011
Internal speakers are disabeled. Extearnal speakers work just fine
Headphone jack may be faulty as there is a contact that tells the uProcessor that the socket is in use and turns the internal speakers off. If the contacts are tarnished, they might not be opperating correcty.
Dec 03, 2013 | Computers & Internet
Dv6000 no sound from internal speakers
If the stereo jack works, then there is no problem with the sound card or its drivers. Your speakers have played their last, most likely some internal wiring broken as speakers themselves rarely just quit.
Jan 12, 2012 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Headphone jack not working
I find that there is a problem with your headphone speaker.
Try with some other headphone, even if it is not working, then you need to take it to the service center.
Cheers,
Mr.Maduraikaran.
Jan 10, 2012 | Acer Computers & Internet
Polk computer speakers work in laptop but not on desktop computer
desktops now a days have more than one plug for the speakers. try playing some music and play which hole works.
if there is a 5.1 or surround on the desktop then most likely the light green jack isnt stereo out but rather unamplified signal. thus when you plug head phones into it the internal amp drives the headphones, but wants the computer to drive the speakers.
try plugging it into the black one... or play pick a hole till it works.
Jun 10, 2010 | Polk Audio AMR2 Computer Speakers
Built in speakers not working
Are you using external speakers? or internal?
EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
Good Luck.
Sep 08, 2009 | HP Compaq nx6115 Notebook
Everything works fine on the unit no problem until
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
if this side of it works then the FM transmitter is faulty
Check that the sound has not been MUTED
plug the earphone into the socket to see if any sound is heard. The socket is also a switch that takes sound from internal speaker to ephone and reverse.
If no sound is hear in either FM or normal mode your unit is faulty and needs repair
Jul 24, 2009 | Garmin nuvi 250W GPS Receiver
My speakers have no sound.
  • after all the testings of the external devices, one thing proves that the internal speaker needs replacement.
Apr 09, 2009 | Dell Vostro 200 Desktop Computer Intel...
Center speaker no longer works
Wiggle the connection that the center one is plugged to. It starts static or playing then the internal connection is broke loose from the solder joint.
Plug another speaker to that connection. If it plays then the speaker is blown.
Feb 17, 2009 | Insignia IS-LCDTV32 32 in. Television
i just had it solved once for my frend. . wat to do is uninstall everything realted to yur sound hardware .. and get the latest updates ... from ..their site ... and install it .. it will work .. before .. doin this just try ....
1 conect the headphone
2 open the mixer .. in that there will selection of device. .. from that select headphone if it is available. ..
thnx
Nov 04, 2008 | Compaq Presario 700 470024-192 Notebook
Power supply
there is an internal fuse in the power supply adapter but you have to cut the box open to get to it.did this myself replaced the fuse and it now works fine
Dec 06, 2007 | JBL CREATURE II Computer Speakers
Packard Bell Speaker Computer Speakers Logo
Top Packard Bell Audio Players & Recorders Experts
David
David
Henry  Thomas
Henry Thomas
SHIVAJI YADAV
SHIVAJI YADAV
Are you a Packard Bell Audio Player and Recorder Expert? Answer questions, earn points and help others
