Question about Rockford Fosgate Car Audio & Video
I bought a 2400 watt punch 801s amp that has two power out and two ground outs i've hooked up only one power and one ground and the amp comes on but as soon as i touch the speacker wire to it it hits one time and it eats the speaker wire up and my question is do i have to hook up boot power outs and both grounds to make it work or what
Check the gauge on the wiring. For that size amp you would need to use 0 AWG wire for the power, the speaker wire is just signal wire so you want to use regular speaker wire. (I have 12 AWG setup for speaker wires) What the two power ports (Neg and Pos) do is increase the amount of flow. Two power wires to distribute the flow of the current so you don't burn up your wires if your pumping too much juice. I started off with this exact amp running a single 8 AWG and split it into two and it burned up and blew a fuse after a couple of huge bass hits. So proper setup would be....
BAT(+)---FUSE HOLDER(60AMP+)---DISTRIBUTION BOX(30AMP+)====AMP
GND(-)===AMP
-- would be 1 wire pref 0 AWG splitting into more 0-4 AWG
== would be the 2 wires (Yes two ground points in separate locations would be better)
Thus finalizing you have a proper setup.
Be careful you don't burn out your alternator, this bad boy can cause some serious problems with a lower amp alternator. Let me know how it works out.
Posted on Apr 21, 2010
Full schematic for punch 801s 2400 watts
Are you interested in the filtering stage or the amplification stage
May 10, 2014 | Rockford Fosgate Car Audio & Video
Hi, I was trying to replace my subs and during the process, the positive wire touched the negative wire and my amp turned off. I have the Punch 801s 2400 watt amp. Is there a way to reset it? I'm assuming...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping. A thumbs up would be greatly appreciated if this answer is helpful to you. GOD BLESS YOU.
Oct 17, 2013 | Rockford Fosgate Punch 801S Car Audio...
I have a rockford fosgate 2400 watt amp 801s it has two power line hooke ups as does the ground is this for a seconde amp or does it need two power wires and two ground wires.the reason i ask is its tends...
The connections you are speaking of are not for a different amp but to provide enough amperage to and from to amp. Your amp is running to hot because the impedance on your subwoffer is to low
Impedance= ohm rating of your speaker
Jul 14, 2011 | Car Audio & Video
Rockford 801s.The ground terminal melted off but still worked when i disonnected it.
It's more than likely melted to the frame of the amp. Since it's melted, you really need to send it in to be fixed or pickup a new amp. It's VERY dangerous to not have it correctly grounded. It could potentially cause a fire.
Apr 19, 2011 | Rockford Fosgate Punch 801S Car Audio...
On the 801s there are 2 power holes and two ground wire holes why...
basically it is so you can get better power and ground connections.
Oct 20, 2009 | Rockford Fosgate Punch 801S Car Audio...
Will my car handle a rockford fosgat 801s power load?
Hello dreww1005,
If your alternator and battery are in good condition, you probably don't need a capacitor. At maximum output, the 801S will need to draw a little over 30 amps at 12.8V. The specifications call for 8-gauge power and ground wiring and a 40A primary fuse. The Vibe's electrical system should be able to handle it OK.
Hope this helps.
May 08, 2009 | Rockford Fosgate Punch 801S Car Audio...
I opened up my. 801s fosgat to adjust gans when it was on. And I turn one of the. Adjust blue. On inside. Top. My. Amp. Pop. Ground. Overheated Woofer overload power now. Only. Rightside. Works and...
the components inside of an amp are only rated for so much power to run through them and u probably turned the pots up to far and did some serious internal damage
Mar 26, 2009 | Rockford Fosgate Punch 801S Car Audio...
I have been having trouble with my car stereo system
First reinspect your power and ground connections, vibration may have loosened them.
Then be sure that amp location has proper ventilation, (overheating will cause shout down)
A 2400 in a closed space will definitely need exhaust fans to help circulate cool air around the amp.
The cap should be mounted close to the amp and properly charged before use. It is connected in-line with the main power lead paying close attention to the power in and power out terminals.
Power in = from the battery
Power out = to the amp
Good luck
Aduz
Mar 15, 2009 | Rockford Fosgate Punch 801S Car Audio...
Car Audio & Video Logo
254 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
