Question about AEG Lavamat 16810 Front Load Washer/Dryer
Hi we have an aeg lavamat turbo L12710 then en error code E40 flashes, so checking with manual it says door problem, switch off but after 30 mins door wont open, so was able to open it and check the interlock, when finally power up the machine error code is gone but the timer starts flashing and water entering is continously being discharged.. already cleaned the filter/pump still same situation.
  • lan_alcera May 21, 2011
    I tried unplugging the connectors to the door interlock switch then attaching it again then tried to power on the machine but no lights on the panel but as i turned on the selector knob the machine starts up but i can see the timer set to 139 flashing then the start/pause intermittently blinks green then off,, then the pump continous to function all the water coming in is continously beng discharged/draines out.. what could be the problem
  • 1463 Answers
SOURCE: AEG Lavamat 1000
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
Posted on Mar 03, 2008
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
Posted on Mar 21, 2009
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump pump.
Posted on Jun 12, 2009
SOURCE: AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Posted on Jun 15, 2009
  • 174 Answers
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Posted on Jul 24, 2010
When I switch on my washing machine AEG Lavamat turbo 16800 it displays E40
HI Mike.
E40 relates to the door being left open when the programme is started, it maybe that the latch was not pushed over when the door was shut.
to solve the problem get another switch.
hope this helps you.
or read up some more at this link.
washing machine AEG Lavamat turbo 16800 it displays E40 Google Search
Dec 20, 2017 | AEG Washing Machines
On an aeg lavamat washer dryer l12710 where is the filter for the dryer I have cleaned the front one for the washer ?/
If you go to and look under "service and support" you will see a box to insert your model number. I've put your model in and there's service manuals in several languages. Happy hunting.
Nov 03, 2014 | AEG Lavamat 12710 Front Load Washer /...
AEG Lavamat washing machine model 76850, shows a blinking key and makes clicks and after that shows E40. Thanks John
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensing circuit faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Aug 02, 2014 | AEG Washing Machines
Its a defective door lock. It might have to be replaced by a techie! Hope its under warranty
Mar 08, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Turned off mid cycle. Tried putting back onfor drain, also rinse and restart. Each time get error E40.
With AEG washers E40 means defective door lock. Since a faulty door lock switch may go out with vibration you often do not get the error all the time. The door lock switch must be tested and eventually replaced. Call the AEG number listed in the user manual if you want to get in touch with an authorized technician or if you need replacement parts for your washing machine.
Sep 18, 2011 | AEG Washing Machines
AEG washing machine error code e40
E40 relates to the door being left open when the programme is started, it maybe that the latch was not pushed over when the door was shut.After the door is closed again the fault should go away. If it does not and you hear alot of clicking from the door lock you may just have a door lock at fault.Code E40 is door not closed, could be a mis-aligned door or faulty door switch.-------------But if door is closing properly and you are confirmed that door is getting properly locked, then other possibility can be gunked filter or blocked drain pump.It requires cleaning internally.The procedure is as follows:--- Towards the bottom right of the machine is a pull-down flap.
Drain the machine - there's a tube at the bottom of the machine
with a plastic plug - you'll see a butterfly handle, pull hard; the plug
is a round ball on the end of a stick.
Unscrew the large diameter thing (pump cover) -
Don't do this before the drain step!!!
Withdraw the filter cylinder and remove any gunge - the
filter port has two ports - the left one is the impellor
pump and the right one is the discharge pipe; feel to ensure
these are not gunged up either.
Reassemble in reverse order - as Haynes say.
Almost every programme necessitates a pump activation to
assure that the machine is empty of water .-----------
Apr 09, 2011 | AEG Lavamat 74640 Front Load Washer
Aeg lavamat error 40e
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board.
Feb 04, 2011 | AEG Lavamat 72640 Front Load Washer
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Aeg 74640 error code e30
What does the E40 error code mean?
Jul 09, 2008 | AEG Lavamat 74640 Front Load Washer
Error message
e40 fault code is water level too low during heat which is very strange to appear at start-up. does anything else happen? without being certain, points to a main module fault
Dec 23, 2006 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
69 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
