Question about Refrigerators
JUST BROUGHT THIS USED FRIDGE MODEL# FTRS20KAL10 YESTERDAY AND PLUGGED IT IN . I PUT ICE CUBE TRAY IN FREEZER TO SEE HOW WAS WORKING. JUST CHECK IT OUT THIS MORNING THE WATER IN TRAY IS JUST SLUSHE AND THE FRIDGE COOL. WHAT DID I NEED TO CHECK TO GET IT WORKING PROPERLY.THX STEVE
  • 8 more comments
  • steveaa56 May 23, 2011
    I CLEANED OUT THE COILS AND UNDERNEATH FRIDGE WITH AND AIR COMPRESSOR AND VACUM ITS WAS PREETY DIRTY. ITS BEEN ON AND RUNNING FOR 48HRS NOW. ,SET BOTH FRIDGE AND FREEZER ON COLDEST TEMP AND PUT A THERMOSTAT IN. AFTER 48HRS THE FREEZER THE BOTTOM SHELF OF FREEZER IS SHOWING TEMP OF 32* BUT THE TOP SHELF IN FREEZER IS AROUND 36* WHICH I THINK IS KIND OF STRANGE. ALSO THE FRIDGE TEMP IS 70*. SO WHAT TO I NEED TO CHECK NOW. THX STEVE
    WHEN I SAID THERMOSTAT I MENT TO SAY THERMOMONETER. THX STEVE
    I CLEANED COMPRESSOR AND COILS WITH AIR COMPRESSOR AND VACUUM. ON SATURDAY MORNING. WAS PRETTY DIRTY. I PUT A THERMOMETER IN FREEZER ON BOTTOM SHELF FOR 12HRS RDING WAS 32* THEN PUT IN FREEZER TOP SHELF FOR 12 HRS RDING OF 36* WHICH I THINK IS KIND OF STRANGE YOU WOULD THINK IT WOULD BE THE SAME. THEN LAST NIGHT PUT THERMOMETER IN FRIDGE SECTION THIS MORNING TEMP. IS SHOWING TO BE 70* SO I', GETTING APPX 32* TO 36* IN FREEZER AND 70 IN FRIDGE. WHAT THE NEXT ITEM TO CHECK. THX STEVE
    I CAN GET THE EQUIPMENT TO INSTALL THE FREON MYSELF. WHAT TYPE OR "#" OF FREON IS IT? HOW MANY LBS. OF PRESSURE IS SUPPOSE TO BE IN LINE? DOES IT HAVE A LOW AND HIGH SIDE PRESSURE LIKE A CAR. IS COMPRESSSOR SUPPOSE TO BE RUNNING WHILE YOU INSTALL THE FREON? CAN YOU GIVE ME STEP BY STEP INSTRUCTION? . THX STEVE
    COULD IT BE THE FAN INSIDE FRIDGE NOT WORKING PROPERLY ? DOESN'T SOUND LIKE ITS COMING ON. OR HOW ABOUT THE DEFROST COULD IT BE STUCK ON CAUSING IT TO BE ON DEFROST ALL THE TIME? THX STEVE
    COULD IT BE THE FAN IN THE FRIDGE NOT WORKING PROPERLY DOESN'T SOUND LIKE IT COMING ON? COULD IT BE THE DEFROSTER NOT TURNING ITSELF OFF CAUSING IT NOT TO CYCLING THE 12HR ON AND 12HR OFF? THX STEVE
    I GOT TO THE FAN IN FREEZER, IT WASN'T TURNING. SO I JUST TURNED IT MANUALLY AND NOW ITS WORKING. I TURN THE THERMOSTAT OFF AND FAN TURN OFF THEN ON AND FAN IS WORKING NOW. THE FINS ON COILING WERE OK JUST ALITTLE ICE ON PART OF THEM. WERE IS THE DEFROST TIMER LOCATED AT ON THIS UNIT? IS IT IN THE FREEZER OR FRIDGE? THX STEVE
    IS THERE ANY WAY TO FIGURE OUT THE AGE OF UNIT?THX STEVE
    I THINK ITS WORKING PROPERLY NOW THE FAN IS ON AND WORKING IN FREEZER. THE TEMPERTURE HAS DROP TO 20* IN FREEZER AND 50* IN FRIDGE. STEVE
    SEEING HOW IT HAS KITCHENAID NAME ON IT WOULD THEY BE THE MANFACTURER CAUSE WHEN IT PUT THE MODEL # IN AND GOOGLE IT COMES UP , SEARS. STEVE
    Genius:
  • 1,400 Answers
Hello
It usually takes 24 hours before the freezer gets below 32.f
Try lowering the temp in the freezer a little.
You need to be at 29.to 30.f
Check the compressor and condensor fan area under the fridge for dust or dirt and clean it out with a vacuum .
Posted on May 23, 2011
  • 3 more comments
  • mpcheesman1
    mpcheesman1 May 23, 2011
    There could be two more possibilities.
    1 bad thermostat.try to replace.I doubt it though.
    2 Low on freon.This would be a service call.More then likely its low on freon.
  • mpcheesman1
    There is a high and low side.The type of freon is listed on the model# plate.Possibly R 12.
    The amount is usually by weight or ounces.To obtain the correct charge you would need to evacuate the entire system.Pull a vacum with a vacum pump then weigh in the freon using a scale.
    A easier way is..With the compressor running put a small amount of freon gas in the low side and watch the pressure on your low side guage.So say we wanted a temp of 28.f using R 12.We would need a low side pressure of 26.9 psig.
    Here is a link to a pressure temp chart
    http://assets.fluke.com/appnotes/electri...
    I dont belive the defrost is broken only beacause your getting 32.f in the freezer.I would however have a look at that fan inside the fridge.That could be a good reason for the big difference in temp between the freezer and refridge.Also check that there is no ice or anything blocking the vent from the freezer to the refigerator.
  • mpcheesman1
    The age would be in the model or serial#.The manufacturer would be able to tell you that.
    As far as location of the timer.It may be under near the compressor.
  • mpcheesman1
    20.f in the freezer is a little cold but its up to you.35 to 48.in the refridge should be good.
  • mpcheesman1
    ok theres really nothing else im going to answer here.seems you have it working.
    Thanks
Ice cube dispenser not working
Hi there, did you find the answer to this problem? We have exactly the same issue. We noticed a burnt smell in the freezer, mainly transferring to our hands when we touched packaging. The ice dispenser was working fine but the ice started to taste funny (a bit like burnt plastic) and had black bits in it. We took it out to clean the tray and since putting it back in, it just won't work. We don't know if we have put it back in wrong or if something has blown. We can still hear the motor when we try to press for ice, but nothing comes out. No water is making its way into the ice cube tray to form the ice, but we still have cold running water. I would be so grateful for any help. Thanks
Mar 16, 2014 | Ovens
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
My fridge wont make ice
you need to replace the ice maker .
Sep 12, 2009 | Refrigerators
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Jul 19, 2009 | Daewoo Refrigerators
Ice maker not dumping as frequently and cubes freezing one large chunk
The first thing I would check is the cleanliness of the condenser coil under the fridge. Make sure the fan under there is running, and that the coil is clear of dust. The ice maker requires 15 degrees for a period of time before it will make ice and dump. If the temp in the freezer is colder than this, then it is likely the ice maker needs replaced. They can be replaced fairly easily with just a couple tools. (1/4" nut driver and a flat screw driver). There is a plug where it plugs into the freezer side wall, and a bent tube that supplies water to the tray. If not sure what to do, have a service tech look at it.
May 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker makes very little ice
my under the counter ice machine makes very little ice. we just paid $600 to have a repairman put a new motor in it (although I don't think that was ever the problem) because it would always run, it was just not making any volume of ice. now it's been fixed and the repairman brought it back under th counter yesterday and it's STILL not making more than maybe 1 cup of ice in over 24 hours. I can hear the water running when Iopen it, but just don't get the bin full of ice like it used to get. HELP!!
Oct 16, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
