Question about Dishwashers
Our dishwasher has a lock on light, we are not sure how it came or what button we pushed, but we can not remove the lock. The machine is about 7 years old so looking in the manuel is not possible....cant seem to find it. Any advice or help would be appreciated
  • 1 more comment
  • us_feba May 25, 2011
    when I push the cancel or start the lock light will flash 3 times every 5 seconds. it will then turn off after 20 and the normal wash light will flash. Once I release the cancel or start button the lock light will then come back on and nothing else will operate
    kenmoreultrawash sensor atc
    MOD- 665.16352301
    stock #- 16352
    type - 575-0
    ser # - fr2110141
    ultra wash sensor atc
    mod - 665.16352301
    stock # - 16352
    type - 575-0
    ser - fr2110141
  • 4,323 Answers
Hi
Please try and press Start/Cancel button for 10-20 seconds. If this doesn't unlock then please post back with make and model# of your washer.
Daniel
Posted on May 21, 2011
  • Daniel Scott
    Daniel Scott May 25, 2011
    Press and hold the AIR DRY/HEATED DRY button for 15 seconds, this will unlock the controls
Dishwasher is locked out. Clean light flashes 7
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Kenmore 17024 Built-in Dishwasher
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Clean light blinks 7 times continuously
If the clean light flashes 7 times, pauses, then repeats...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. Let it go through the diagnostic to test the function of the element.(1-2 minutes). When it finishes, open the door and touch the element to see if it is hot (be careful, it can get pretty hot so wet your fingers to avoid burns).
Once the diagnostic has cleared, you should be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
May 04, 2009 | Kenmore Dishwashers
''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Apr 01, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Mar 26, 2009 | Dishwashers
I have a Kenmore Elite Ultra Dishwasher and the cleaning light is flashing. I have tried pressing the start/resume button and closing the door within 3 seconds. I am not able to turn on my dishwasher. I...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 02, 2009 | Dishwashers
Blinking clean light
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Dishwasher light flashes 7 times
although i dont have a lookup for your particular model number. if you remove the lower access panel you will find techsheet/troubleshooter. in it there will be section on "clen light blinking 7x" foplloe direction to put into test mode to clear the fault. belive its,,, heated dry/ sani rinse / heated dry/sani rinse. pushing htese buttons is what gets into test mode
Dec 11, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
DISHWASHER LOCK
I too had the same problem,,and tried it again,,,and it worked for me,,i pushed the button next to the lock light it blinked and i kept holding in the dry button and the lock went off,,,,good luck
Aug 15, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Ultra Dishwasher. Model 665.15772990
There should be a button on the machine with a padlock symbol. Hold it down for 4 seconds to unlock it. If you want to lock it again, hold it down for 4 seconds to turn it on.
Jun 01, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
