Question about Whirlpool LEN2000PW Dryer
How do you gain access to rge belt drive to replace broken belt on the LEN2000LW dryer.
    President:
  • 3,074 Answers
You will need to open the cabinet:
http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
then replace the belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
hope the helped Tim
Posted on May 21, 2011
Samsung dryer hums but the drum does not turn
It sounds to me like the drive belt that goes around your dryer tub has broken.
images?q=tbn:and9gcqu5itfzbd0xyagva6nfwjbc486ekglruzljwmfemwgndlj-mg5tw
The back of the dryer will need to be removed to gain access to the problem.
Oct 27, 2012 | Samsung DV448AEP 7.4 Cu. Ft. Electric...
I want to replace the drive belt
Hello - What is the length of the belt? Can you provide the exact model number for this unit?
Sep 27, 2012 | Electrolux EW1200i Front Load Washer /...
Drive belt is broken. How much disassemly is required to insert a new one around the drum?
usually you can remove the top panel and then on the inside you will see screws holding the front panel ...you will have to remove that.. if someone assist you they can hold tub up in place and keep it resting on back rollers while you gain access to under side of tub and route belt around tub and against tensioner to install new belt... a little time consuming but can be done by the do it yourselfer... wish you luck....
Feb 03, 2011 | Frigidaire GLEQ642A Electric Dryer
After I push start button sensing light turn on,but dryer does not work,just click.
sounds like you have a broken belt
first remove the lint trap
remove the 2 screws
unplug the dryer from wall
lift thhe lid
you will have access to the drum
is the belt still in tact
if you cannot see the belt that is you problem
another option open the door you have a door switch in the upper left or right corner
when you close the door, does the door hit the switch ?
if not you have a bad lid switch
which you can gain access to it the same way as the above to access the belt
Aug 24, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer won't spin and there is a deep humming sound with an electrical odor
Sounds like the drive belt has broken and is rubbing against the motor pulley, which causes the smell.
You can order a new one online, or from Sears. Replacement is a matter of gaining access to the inside of the dryer, remove the old belt, and figuring out how to get the new belt around the drum and motor pulley.
Dec 11, 2009 | Whirlpool Dryers
Gaining access to change a drive belt on mower
the belt cover should have screws with the heads on top of the deck, then there is a guide which keeps the belt in the engine pulley with 2 or 3 bolts you might be able ot get it on the gearbox with just those off and a bit of prying etc.
Sep 13, 2009 | Garden
Replace bearing and bushing g.e. profile dryer
Yes, but you will have to swing the top open, remove the dryer front, and pull the drum forward about 4 inches (leaving belt on drum) to gain access to the bushing. Normally that is all you have to replace, but also check for wear on the front drum slides at the same time.
Jan 21, 2009 | GE Dryers
Drive belt replacement on a Miele T230C tumble dryer
You must route the belt either in front of or slip it behind the drum to get it down to the drive wheel. You should remove the front panel to be able to do this the best.
Jul 05, 2008 | Dryers
Whirlpool LEN2000PW Dryer Logo
268 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
