Question about Cycling
The gears do not shift only half will - Cycling
  • mh May 21, 2011
    what drive train do you have SRAM, or campy?
    Problem Solver:
  • 15 Answers
Loosen up the nut of the speed cable then put the chain on the bigger spracket in backwheel then tighten up.
Posted on May 21, 2011
Wont shift into 3rd gear at all anymore, 1st and 2nd gears shift through fine
Failed transaxle
Sort of old to invest in a rebuild
I can not tell you how many of those caravans I did
at my trans shop in the early to mid 90's
They fail a lot & over & over again
Jul 19, 2014 | 1998 Dodge Grand Caravan
Kia Spectra 2nd to 3rd gear having shifting problem
Could be the transmission shift solenoids.
I've replaced dozens and so far, that was the problem every time.
Mar 18, 2014 | Cars & Trucks
2001 honda xr200 6th gear
Most likely cause of not selecting a single gear is a bent shift fork.
Shift forks in motorcycles are what pushes the gears in and out on the shaft to engage them. Rough shifting or missing gears can sometimes cause them to bend.
Replacing them, however, requires removing and completely re-building the engine as the shift forks are right inside.
Alternatively it could be a damaged shift drum, but again it's a case of remove engine, split motor in half and have a look.
For a look at the gearbox itself, go to http://www.boltonmotorcycles.com/find/unit/8488
and select 'Transmission' and 'Shift Drum/Fork'
Nov 17, 2013 | Honda XR 200 Motorcycles
Can't shift 2002 Durango into gear.
repair the selector system first then ask what to do
Oct 14, 2017 | 2002 Dodge Durango
I've got a 1996 Kawasaki ZX6R. The bike runs great. However, it will shift down into first gear, but won't shift up past neutral. Any thoughts? Thanks, Lance
The bike has a bent shift fork. The engine must come out then gets flipped upside down to remove the bottom half of the crankcase. This allows access to the gears and shift forks. The repair is not recommended for the home mechanic. Please rate my answer. Thanks. tombones49_211.gif
Jul 14, 2011 | 1996 kawasaki ZX-6R Ninja
I have a Kawasaki zx550A1 (GPz550), it shifts into 1st and 2nd just fine but won't shift any higher. It's almost like there is no more gears.
The bike has a bent shift fork in the transmission. You describe the classic symptoms. The engine will have to come out of the frame. Then it gets flipped upside down, right and left side covers, shift shaft, and other components are removed, then the bottom half of the gearbox is removed. This allows access to the shift drum and shift forks. There are some special tools needed and I don't recommend a novice mechanic tackles the job. Below is a diagram of how the shift drum moves the shift forks left and right to make a slider gear engage different gears. Please rate my answer. Thanks. tombones49_119.gif
Apr 27, 2011 | 1984 kawasaki Z 550 F
Transmission will not downshift without force
You have a bent shift fork. The engine needs to be removed from the frame then the bottom half of the engine center case gets separated from the top half. This allows access to the gears, shift drum and shift forks. Please rate my answer. Thanks.
Aug 26, 2010 | 1985 Honda CB 700 SC Nighthawk
Hard to change into 1 st and 2nd gear . quickshifter fitted . does engine have to come out to work at gearbox
Remove the quick shifter and see if the shifting problem is still there. If so, you have a bent shift fork. Yes, the entire engine comes out and then the bottom case half is removed to gain acess to the gears and shift forks.
Jul 14, 2009 | 2008 Yamaha YZF-R6
Cant shift in my 88 crx
I would recommend flushing the tranny fluid. you could go with GM synchromesh fluid found at the GM dealer and it will make the shifting buttery smooth. I use this all the time. appx 2 quarts.
Apr 08, 2009 | 1990 Honda CRX
Cycling Logo
41 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
