Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My Kingston usb flashdrive 16 Gb files was corrupted and so with the installer. Everytime when I insert it shows unknown driver and it's not working. Can you provide us the the installer with this type of usb flash driver. Thank you very much.
  • 4,338 Answers
You do not need drivers for flash drives. The problem may be your USB ports.
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If it turns out that the files are indeed corrupted, there are several free recovery programs you can try.
http://www.easeus.com/resource/drive/usb-flash-drive.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on May 21, 2011
Flash drive file system unknown and unformatable
Sounds like the partition table is screwed up. I've tried simulating it as best I could. I created a 25 MB drive in this video and edited the partition table to show only 2 KB. Formatting only allows me to format the 2KB in your case it would be 0KB and formatting won't do anything. Try the steps in the video.
Jan 31, 2013 | SanDisk Electronics - Others
My flashdrive won't respond at all. I think that it was somehow disconnected on the inside, but I have no way of knowing. Is there any way that I can retrieve the data or fix the flashdrive?
you can try some data recovery software. You can see
http://www.asoftech.com/articles/undelete-files-from-usb-drive.html
It tells the steps how to perform data recovery.
If above does not work, you may have to format the flash drive (use quick format), and then use above mentioned software to scan again the flash drive and recover your files.
Sep 05, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
I connecting my kingstone pendrive(32gb), after pasting some files (any video,audio,etc) that files are danaged in pendrivem plz solve problem
insert 32 or 2 GB USB go to control panel administrive tools computer management disk mangement you can defragment this USB drive or you can right click select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
hope this helps
Oct 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
The file system is unknown
The file system is likely corrupted. This can happen if you remove the usb drive from the computer without clicking "Safely remove hardware' first, (in your taskbar).
There is little chance that you can recover the data.
Just in case, try inserting the drive into different usb ports, preferably also on different computers. If the result is always the same, you will have to format your drive.
Insert the drive into a usb port. Assuming you use windows, click Start, click My Computer, find your USB drive in the list and RIGHT click on it. You will see a Format option. Click on that and use default or FAT. A quick format should do.
Good luck.
Apr 05, 2010 | Kingston (SDCZ2-512-A10-KT)...
I can't format my 2gb kingston data traveler 2ntfs and it stores only less than 28 mb. i can only use this data traveler on my microsoft office word and excel files but about my audio files, all could be...
I have kingston datatraveler 200 (64gb) and I backum 4gb`s on that usb, but when I want to opet that, its corrupted, damaged and now I cant even format my usb.. help
Dec 18, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
32Gb kingston pendrive not working. Any data copied get corrupted
When i copy any data to my 32 Gb Kingston pen drive whether any audio or video file or any software, the data get corrupted or may be deleted. some trimes it happen that some of the AV files are working. Why this happened that the data are deleted. I have lost many of my files due to this.It cannot be fomatted also. Please sort my this problem. Thanx
Jun 27, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston 2gb drive s not detcted by the system
yaar meri pan drive open nahi ho rahi hai na hi format ho rahi hai
Feb 13, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My Kingston 8 GB drive shows data into other format. If there is 2 GB of data, sometimes it shows there is 3 GB or more. The data inside my drive shows unknown symbols or something like that. Please help...
If there are such unknown folders and files in your pen drive and you did not place them there, then you have reasons to be cautious. Try to run a virus scan, these night be trojans or worms, etc. or copy/backup the important files in your pen drive then, format your pendrive.
Apr 06, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
109 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
